[petsc-users] Some questions in PETSc installation.
Thu Nov 15 12:50:39 CST 2012
On Thu, Nov 15, 2012 at 1:18 PM, paul zhang <paulhuaizhang at gmail.com> wrote:
> Hi Matt,
> Do you have some idea to install   f2cblas and  f2clapack to /usr/lib on my
> local Ubuntu? Since PETSc needs them.
Just use --download-f-blas-lapack.
   Matt
> Thanks,
> Paul
> On Thu, Nov 15, 2012 at 12:30 PM, huaibao zhang <paulhuaizhang at gmail.com>
> wrote:
>> Thanks a lot for your help Matt.
>> Paul
>> Huaibao (Paul) Zhang
>> Gas Surface Interactions Lab
>> Department of Mechanical Engineering
>> University of Kentucky,
>> Lexington, KY, 40506-0503
>> Office: 216 Ralph G. Anderson Building
>> Web:gsil.engineering.uky.edu
>> On Nov 15, 2012, at 12:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Nov 15, 2012 at 12:23 PM, paul zhang <paulhuaizhang at gmail.com>
>> wrote:
>> Hi there,
>> Can I get some help to solve this issue?
>> [hzh225 at dlxlogin2-2 petsc-3.1-p4]$ make
>> PETSC_DIR=/home/hzh225/LIB_CFD/PETSC
>> test
>> Running test examples to verify correct installation
>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
>> process
>> See
>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
>> This is not our message. It comes from your MPI.
>>  Matt
>> WARNING: It appears that your OpenFabrics subsystem is configured to only
>> allow registering part of your physical memory.  This can cause MPI jobs
>> to
>> run with erratic performance, hang, and/or crash.
>> This may be caused by your OpenFabrics vendor limiting the amount of
>> physical memory that can be registered.  You should investigate the
>> relevant Linux kernel module parameters that control how much physical
>> memory can be registered, and increase them to allow registering all
>> physical memory on your machine.
>> Lexington,
>> KY, 40506-0503
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
> Lexington,
> KY, 40506-0503
-- Norbert Wiener
