[petsc-users] Some questions in PETSc installation.
huaibao zhang paulhuaizhang at gmail.com
Thu Nov 15 11:30:28 CST 2012
Thanks a lot for your help Matt.
Paul
Huaibao (Paul) Zhang
Gas Surface Interactions Lab
Department of Mechanical Engineering
University of Kentucky,
Lexington, KY, 40506-0503
Office: 216 Ralph G. Anderson Building
Web:gsil.engineering.uky.edu
On Nov 15, 2012, at 12:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Nov 15, 2012 at 12:23 PM, paul zhang <paulhuaizhang at gmail.com> wrote:
>> Hi there,
>> Can I get some help to solve this issue?
>> [hzh225 at dlxlogin2-2 petsc-3.1-p4]$ make PETSC_DIR=/home/hzh225/LIB_CFD/PETSC
>> test
>> Running test examples to verify correct installation
>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
>> process
>> See http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html
> This is not our message. It comes from your MPI.
>  Matt
>> WARNING: It appears that your OpenFabrics subsystem is configured to only
>> allow registering part of your physical memory.  This can cause MPI jobs to
>> run with erratic performance, hang, and/or crash.
>> This may be caused by your OpenFabrics vendor limiting the amount of
>> physical memory that can be registered.  You should investigate the
>> relevant Linux kernel module parameters that control how much physical
>> memory can be registered, and increase them to allow registering all
>> physical memory on your machine.
>> Lexington,
>> KY, 40506-0503
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121115/47949c69/attachment.html>
