[petsc-users] Does PETSc take advantage of symmetry in iterative solvers
Alexander Grayver agrayver at gfz-potsdam.de
Mon Nov 12 08:43:27 CST 2012
On 12.11.2012 13:40, Jed Brown wrote:
> The option does not change the format, but it does change some
> defaults (e.g., it makes ASM symmetric instead of using RASM). If you
> want to use a symmetric _format_, use MATSBAIJ.
Jed,
Thanks.
Does it make sense that in fortran one has to call MatCreateMPISBAIJ?
/EXTERN_C_BEGIN
void PETSC_STDCALL matcreatempisbaij_(MPI_Comm *comm,PetscInt
*bs,PetscInt *m,PetscInt *n,PetscInt *M,PetscInt *N,
          PetscInt *d_nz,PetscInt *d_nnz,PetscInt *o_nz,PetscInt
*o_nnz,Mat *newmat,PetscErrorCode *ierr)
   CHKFORTRANNULLINTEGER(d_nnz);
   CHKFORTRANNULLINTEGER(o_nnz);
   *ierr = MatCreateSBAIJ(MPI_Comm_f2c(*(MPI_Fint
*)&*comm),*bs,*m,*n,*M,*N,*d_nz,d_nnz,*o_nz,o_nnz,newmat);
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121112/1418a2fa/attachment.html>
