[petsc-users] Benchmarking different PETSc installations
Fri Nov 9 12:43:36 CST 2012
Run examples that are representative of a workload you are interested in.
src/snes/examples/tutorials/ex5.c is a simple problem that is easy to
understand. Use a 3D problem if that's what you're interested in. Run with
-log_summary to get detailed information. Read the user's manual section on
profiling for more details.
On Fri, Nov 9, 2012 at 11:20 AM, Reuben D. Budiardja <reubendb at utk.edu>wrote:
> Hello,
> I would like to compare / benchmark several different PETSc installations
> on my
> system. The differences may be: different compilers or compiler flags,
> different
> libraries used by PETSc (e.g. BLAS&LAPACK, and any other packages used by
> PETSc that I included in the build like SuperLU_Dist, Metis/ParMetis,
> Hypre,
> etc). Some of these libraries were provided by different vendors and some
> we
> built ourselves and I'd like to compare the performances as used by PETSc.
> So I am wondering if there's any kind of general PETSc benchmarking code
> out
> there that can do this. The more thorough parts of PETSc that gets
> exersized
> by the benchmark code the better, but even if only parts are tested it'd be
> useful too. Also I'm more interested on the benchmark code that can run
> with
> larger number of processors (e.g. order of hundreds and thousands). I've
> tried
> Google search but that hasn't yielded much of anything. So any help in
> pointing me to the right direction is greatly appreciated.
> Thank you
> RDB
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121109/012e3aa5/attachment-0001.html>
