[petsc-users] Fwd: error messages while updating petsc-dev
Thu Nov 8 14:43:29 CST 2012
> > > > > M src/ksp/ksp/examples/tutorials/makefile
You have modified the makefile [perhaps with bad syntax].
So look at the line number pointed by the error message - and fix it
Or 'hg revert src/ksp/ksp/examples/tutorials/makefile' to get rid of your changes.
Satish.
On Thu, 8 Nov 2012, Zhenglun (Alan) Wei wrote:
> Dear Satish,
>     It is amazing that it works. However, I still have the problem when I was
> trying to 'make ex45' in /src/ksp/ksp/example/tutorial saying:
> makefile:7: *** missing separator.  Stop.
> thanks,
> Alan
> > save './$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py'
> > rm -rf externalpackages PETSC_ARCH
> > and retry [configure/make] - and then send us the logs.
> > Satish
> > > Yes, it has some problem when I run
> > > and similar problem when I do 'make'
> > > I will send the log file to petsc-maint in 10 mins.
> > > thanks,
> > > Alan
> > > > ok. Can you rerun configure now [or run
> > > > ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py] and then 'make'. If you
> > > > still have issues - send the new logs to petsc-maint.
> > > > Satish
> > > > > *_hg parent_*
> > > > > changeset:   24846:6e281c3f1f72
> > > > > tag:         tip
> > > > > user:        Matthew G Knepley <knepley at gmail.com>
> > > > > date:        Thu Nov 08 11:41:01 2012 -0500
> > > > > summary:     Manual: Added part of a section on DMComplex
> > > > > _*hg tip*_
> > > > > tag:         tip
> > > > > _*hg status*_
> > > > > M src/ksp/ksp/examples/tutorials/ex10.c
> > > > > M src/ksp/ksp/examples/tutorials/ex11f.F
> > > > > M src/ksp/ksp/examples/tutorials/ex13f90.F
> > > > > M src/ksp/ksp/examples/tutorials/ex14f.F
> > > > > M src/ksp/ksp/examples/tutorials/ex15f.F
> > > > > M src/ksp/ksp/examples/tutorials/ex1f.F
> > > > > M src/ksp/ksp/examples/tutorials/ex21f.F
> > > > > M src/ksp/ksp/examples/tutorials/ex27.c
> > > > > M src/ksp/ksp/examples/tutorials/ex29.c
> > > > > M src/ksp/ksp/examples/tutorials/ex2f.F
> > > > > M src/ksp/ksp/examples/tutorials/ex3.c
> > > > > M src/ksp/ksp/examples/tutorials/ex43-solCx.h
> > > > > M src/ksp/ksp/examples/tutorials/ex43.c
> > > > > M src/ksp/ksp/examples/tutorials/ex44f.F90
> > > > > M src/ksp/ksp/examples/tutorials/ex45.c
> > > > > M src/ksp/ksp/examples/tutorials/ex49.c
> > > > > M src/ksp/ksp/examples/tutorials/ex50.c
> > > > > M src/ksp/ksp/examples/tutorials/ex52.c
> > > > > M src/ksp/ksp/examples/tutorials/output/ex10_24.out
> > > > > M src/ksp/ksp/examples/tutorials/output/ex10_25.out
> > > > > M src/ksp/ksp/examples/tutorials/output/ex22_1.out
> > > > > M src/ksp/ksp/examples/tutorials/output/ex43_1.out
> > > > > M src/ksp/ksp/examples/tutorials/output/ex4_1.out
> > > > > A src/ksp/ksp/examples/tutorials/ex22.c
> > > > > A src/ksp/ksp/examples/tutorials/ex47.c
> > > > > ! src/ksp/ksp/examples/tutorials/data/elem_2d_pln_strn_v_25.txt
> > > > > ! src/ksp/ksp/examples/tutorials/data/elem_2d_therm.txt
> > > > > ! src/ksp/ksp/examples/tutorials/data/elem_3d_elast_v_25.txt
> > > > > ! src/ksp/ksp/examples/tutorials/ex42-mgfs.opts
> > > > > ! src/ksp/ksp/examples/tutorials/ex42-mgfs2.opts
> > > > > ! src/ksp/ksp/examples/tutorials/output/ex4_0.out
> > > > > ! src/ksp/ksp/examples/tutorials/output/ex4_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/AlanRun
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/Rank0Coord.xyz
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/Rank0plt3d.q
> > > > > src/ksp/ksp/examples/AlanTutorials20120409/data/elem_2d_pln_strn_v_25.txt
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/data/elem_2d_therm.txt
> > > > > src/ksp/ksp/examples/AlanTutorials20120409/data/elem_3d_elast_v_25.txt
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/data/ex33bc.data
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex1.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex10.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex11.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex11f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex12.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex13.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex13f90.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex14f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex15.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex15f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex16.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex1f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex2.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex20options
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex21f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex22.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex22f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex23.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex25.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex27.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex28.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex29.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex2f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex3.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex30.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex31.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex32.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex34.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex35.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex37.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex38.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex39.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex4.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex40.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex41.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex41.m
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-fsschur.opts
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgfs.opts
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgfs2.opts
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgschur.opts
> > > > > src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgschur_nestedfs.opts
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex42.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex43-solCx.h
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex43.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex44f.F90
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex45.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex46.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex47.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex49.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex5.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex50.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex51.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex52.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex53.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex54.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex55.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex56.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex6f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex7.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex8.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex8g.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/ex9.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/makefile
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_10.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_11.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_12.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_13.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_14.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_15.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_16.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_17.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_18.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_22.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_23.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_24.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_25.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_4.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_5.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_6.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_7.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_8.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_9.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_ILU.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_cg_singlereduction.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mpicrl.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mpicsrperm.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mumps.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mumps_redundant.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_seqcrl.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_seqcsrperm.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_umfpack.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex11_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex11f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex12_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex12_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex12_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex13_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex13f90_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex14_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex14_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex15_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex15f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex16_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex18_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex20_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex20_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex21f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex22_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex23_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex23_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex25_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex26_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex29_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex29_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_4.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_5.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_6.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_7.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_bjacobi.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_bjacobi_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_bjacobi_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_chebyest_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_chebyest_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_specest_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_specest_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_umfpack.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex30_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex32_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex38_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex39_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex40_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex42_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex43_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex45_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex45_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex49_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex49_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex49_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex4_0.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex4_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex4_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex52_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex53.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex54_0.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex54_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex55_0.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex55_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex56_0.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_4.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_5.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_plapack.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex6f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex7_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex8g_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex8g_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex8g_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex9_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/AlanRun
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/data/ex33bc.data
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex1.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex10.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex11.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex11f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex12.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex13.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex13f90.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex14f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex15.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex15f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex16.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex1f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex2.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex20options
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex21f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex22.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex22f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex23.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex25.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex27.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex28.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex29.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex2f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex3.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex30.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex31.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex32.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex34.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex38.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex39.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex4.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex40.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex41.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex41.m
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex42-fsschur.opts
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex42-mgschur.opts
> > > > > src/ksp/ksp/examples/AlanTutorials20120410/ex42-mgschur_nestedfs.opts
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex42.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex43-solCx.h
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex43.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex44f.F90
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex45.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex45f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex46.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex47.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex49.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex5.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex50.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex51.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex52.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex53.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex54.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex54f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex55.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex56.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex57f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex58.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex6f.F
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex7.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex8.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex8g.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/ex9.c
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/makefile
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_10.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_11.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_12.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_13.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_14.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_15.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_16.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_17.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_18.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_22.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_23.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_24.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_25.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_4.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_5.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_6.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_7.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_8.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_9.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_ILU.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_cg_singlereduction.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mpicrl.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mpicsrperm.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mumps.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mumps_redundant.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_seqcrl.out
> > > > > src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_seqcsrperm.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_umfpack.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex11_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex11f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex12_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex12_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex12_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex13_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex13f90_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex14_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex14_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex15_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex15f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex16_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex18_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex20_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex20_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex21f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex22_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex23_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex23_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex25_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex25_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex26_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex28_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex29_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex29_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_4.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_5.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_6.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_7.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_bjacobi.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_bjacobi_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_bjacobi_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_specest_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_specest_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_umfpack.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex30_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex32_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex34_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex38_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex39_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex40_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex42_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex43_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex43_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex45_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex45_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex45f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex49_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex49_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex49_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex4_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex50.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex50_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex52_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex53.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54_0.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54f.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex55_0.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex55_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex56_0.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex58.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_4.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_5.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_plapack.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex6f_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex7_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex8g_1.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex8g_2.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex8g_3.out
> > > > > ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex9_1.out
> > > > > *_hg pull_*
> > > > > pulling from http://petsc.cs.iit.edu/petsc/petsc-dev
> > > > > searching for changes
> > > > > no changes found
> > > > > _*hg update*_
> > > > > 0 files updated, 0 files merged, 0 files removed, 0 files unresolved
> > > > > _*hg status
> > > > > *_M src/ksp/ksp/examples/tutorials/ex10.c
> > > > > _*cd config/BuildSystem
> > > > > hg parent*_
> > > > > changeset:   2878:3d4bb7478b00
> > > > > tag:         tip
> > > > > user:        Barry Smith <bsmith at mcs.anl.gov>
> > > > > date:        Wed Nov 07 20:34:01 2012 -0600
> > > > > summary:     added support for
> > > > > --with-PACKAGENAME-pkg-config[=pathtosearch]
> > > > > _*hg tip*_
> > > > > tag:         tip
> > > > > _*hg status*_
> > > > > no output
> > > > > _*hg pull*_
> > > > > pulling from http://petsc.cs.iit.edu/petsc/BuildSystem
> > > > > no changes found
> > > > > _*hg update*_
> > > > > _*hg status
> > > > > *_no output
> > > > > > please copy/paste the output of the following commands
> > > > > > hg parent
> > > > > > hg tip
> > > > > > hg status
> > > > > > hg pull
> > > > > > hg update
> > > > > > hg status
> > > > > > hg parent
> > > > > > hg tip
> > > > > > hg status
> > > > > > hg pull
> > > > > > hg update
> > > > > > hg status
> > > > > > Satish
> > > > > > > Thanks for your reply, Dr. Balay.
> > > > > > >         However, I do not know how to get the latest version of
> > > > > > > petsc-dev
> > > > > > > except
> > > > > > > following http://www.mcs.anl.gov/petsc/developers/index.html
> > > > > > > |cd petsc-dev||
> > > > > > > hg pull -u
> > > > > > > ||make
> > > > > > > Those are all what I did. Should I do something else?
> > > > > > > thanks,
> > > > > > > Alan
> > > > > > > > > Dear folks,
> > > > > > > > >         I came across an error while making a code:
> > > > > > > > >         This happens after I was tying to update the petsc-dev
> > > > > > > > > with
> > > > > > > > > some
> > > > > > > > > error
> > > > > > > > > message; the configure.log, error.log and make.log are
> > > > > > > > > attached.
> > > > > > > > > I've
> > > > > > > > > already
> > > > > > > > > sent it to petsc-maint list. Is this makefile error related to
> > > > > > > > > the
> > > > > > > > > fail
> > > > > > > > > update?
> > > > > > > >          This is a Mercurial clone
> > > > > > > >             Defined "VERSION_HG" to
> > > > > > > > ""85e6055943e0711fccdec2d08caeba48971d3d55""
> > > > > > > >             Defined "VERSION_DATE_HG" to ""Fri Sep 23 14:46:14
> > > > > > > > 2011
> > > > > > > > -0700""
> > > > > > > >             Defined "VERSION_BS_HG" to
> > > > > > > > ""e9fd775ab2bf270a9204f7cbc33603292ac5b1d8""
> > > > > > > >             Defined "VERSION_BS_DATE_HG" to ""Fri Sep 16
> > > > > > > > 17:33:47
> > > > > > > > 2011
> > > > > > > > +0200""
> > > > > > > > You don't have the latest petsc-dev. Can you pull the latest
> > > > > > > > petsc-dev
> > > > > > > > and
> > > > > > > > retry?
> > > > > > > > Satish
