[petsc-users] Fwd: error messages while updating petsc-dev
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Thu Nov 8 14:40:44 CST 2012
Dear Satish,
     It is amazing that it works. However, I still have the problem when
I was trying to 'make ex45' in /src/ksp/ksp/example/tutorial saying:
makefile:7: *** missing separator.  Stop.
thanks,
Alan
> save './$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py'
> rm -rf externalpackages PETSC_ARCH
> and retry [configure/make] - and then send us the logs.
> Satish
> On Thu, 8 Nov 2012, Zhenglun (Alan) Wei wrote:
>> Yes, it has some problem when I run
>> and similar problem when I do 'make'
>> I will send the log file to petsc-maint in 10 mins.
>> thanks,
>> Alan
>>> ok. Can you rerun configure now [or run
>>> ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py] and then 'make'. If you
>>> still have issues - send the new logs to petsc-maint.
>>> Satish
>>>> *_hg parent_*
>>>> changeset:   24846:6e281c3f1f72
>>>> tag:         tip
>>>> user:        Matthew G Knepley <knepley at gmail.com>
>>>> date:        Thu Nov 08 11:41:01 2012 -0500
>>>> summary:     Manual: Added part of a section on DMComplex
>>>> _*hg tip*_
>>>> tag:         tip
>>>> _*hg status*_
>>>> M src/ksp/ksp/examples/tutorials/ex10.c
>>>> M src/ksp/ksp/examples/tutorials/ex11f.F
>>>> M src/ksp/ksp/examples/tutorials/ex13f90.F
>>>> M src/ksp/ksp/examples/tutorials/ex14f.F
>>>> M src/ksp/ksp/examples/tutorials/ex15f.F
>>>> M src/ksp/ksp/examples/tutorials/ex1f.F
>>>> M src/ksp/ksp/examples/tutorials/ex21f.F
>>>> M src/ksp/ksp/examples/tutorials/ex27.c
>>>> M src/ksp/ksp/examples/tutorials/ex29.c
>>>> M src/ksp/ksp/examples/tutorials/ex2f.F
>>>> M src/ksp/ksp/examples/tutorials/ex3.c
>>>> M src/ksp/ksp/examples/tutorials/ex43-solCx.h
>>>> M src/ksp/ksp/examples/tutorials/ex43.c
>>>> M src/ksp/ksp/examples/tutorials/ex44f.F90
>>>> M src/ksp/ksp/examples/tutorials/ex45.c
>>>> M src/ksp/ksp/examples/tutorials/ex49.c
>>>> M src/ksp/ksp/examples/tutorials/ex50.c
>>>> M src/ksp/ksp/examples/tutorials/ex52.c
>>>> M src/ksp/ksp/examples/tutorials/makefile
>>>> M src/ksp/ksp/examples/tutorials/output/ex10_24.out
>>>> M src/ksp/ksp/examples/tutorials/output/ex10_25.out
>>>> M src/ksp/ksp/examples/tutorials/output/ex22_1.out
>>>> M src/ksp/ksp/examples/tutorials/output/ex43_1.out
>>>> M src/ksp/ksp/examples/tutorials/output/ex4_1.out
>>>> A src/ksp/ksp/examples/tutorials/ex22.c
>>>> A src/ksp/ksp/examples/tutorials/ex47.c
>>>> ! src/ksp/ksp/examples/tutorials/data/elem_2d_pln_strn_v_25.txt
>>>> ! src/ksp/ksp/examples/tutorials/data/elem_2d_therm.txt
>>>> ! src/ksp/ksp/examples/tutorials/data/elem_3d_elast_v_25.txt
>>>> ! src/ksp/ksp/examples/tutorials/ex42-mgfs.opts
>>>> ! src/ksp/ksp/examples/tutorials/ex42-mgfs2.opts
>>>> ! src/ksp/ksp/examples/tutorials/output/ex4_0.out
>>>> ! src/ksp/ksp/examples/tutorials/output/ex4_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/AlanRun
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/Rank0Coord.xyz
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/Rank0plt3d.q
>>>> src/ksp/ksp/examples/AlanTutorials20120409/data/elem_2d_pln_strn_v_25.txt
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/data/elem_2d_therm.txt
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/data/elem_3d_elast_v_25.txt
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/data/ex33bc.data
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex1.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex10.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex11.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex11f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex12.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex13.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex13f90.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex14f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex15.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex15f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex16.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex1f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex2.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex20options
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex21f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex22.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex22f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex23.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex25.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex27.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex28.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex29.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex2f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex3.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex30.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex31.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex32.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex34.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex35.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex37.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex38.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex39.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex4.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex40.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex41.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex41.m
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-fsschur.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgfs.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgfs2.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgschur.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex42-mgschur_nestedfs.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex42.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex43-solCx.h
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex43.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex44f.F90
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex45.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex46.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex47.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex49.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex5.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex50.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex51.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex52.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex53.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex54.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex55.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex56.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex6f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex7.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex8.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex8g.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/ex9.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/makefile
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_10.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_11.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_12.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_13.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_14.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_15.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_16.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_17.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_18.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_22.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_23.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_24.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_25.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_4.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_5.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_6.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_7.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_8.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_9.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_ILU.out
>>>> src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_cg_singlereduction.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mpicrl.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mpicsrperm.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mumps.out
>>>> src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_mumps_redundant.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_seqcrl.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_seqcsrperm.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex10_umfpack.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex11_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex11f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex12_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex12_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex12_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex13_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex13f90_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex14_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex14_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex15_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex15f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex16_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex18_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex1f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex20_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex20_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex21f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex22_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex23_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex23_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex25_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex26_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex29_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex29_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_4.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_5.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_6.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_7.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_bjacobi.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_bjacobi_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_bjacobi_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_chebyest_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_chebyest_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_specest_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_specest_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2_umfpack.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex2f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex30_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex32_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex38_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex39_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex40_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex42_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex43_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex45_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex45_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex49_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex49_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex49_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex4_0.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex4_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex4_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex52_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex53.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex54_0.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex54_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex55_0.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex55_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex56_0.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_4.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_5.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex5_plapack.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex6f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex7_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex8g_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex8g_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex8g_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120409/output/ex9_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/AlanRun
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/data/ex33bc.data
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex1.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex10.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex11.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex11f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex12.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex13.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex13f90.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex14f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex15.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex15f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex16.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex1f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex2.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex20options
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex21f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex22.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex22f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex23.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex25.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex27.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex28.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex29.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex2f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex3.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex30.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex31.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex32.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex34.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex38.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex39.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex4.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex40.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex41.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex41.m
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex42-fsschur.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex42-mgschur.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex42-mgschur_nestedfs.opts
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex42.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex43-solCx.h
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex43.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex44f.F90
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex45.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex45f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex46.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex47.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex49.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex5.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex50.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex51.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex52.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex53.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex54.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex54f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex55.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex56.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex57f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex58.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex6f.F
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex7.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex8.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex8g.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/ex9.c
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/makefile
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_10.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_11.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_12.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_13.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_14.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_15.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_16.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_17.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_18.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_22.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_23.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_24.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_25.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_4.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_5.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_6.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_7.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_8.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_9.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_ILU.out
>>>> src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_cg_singlereduction.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mpicrl.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mpicsrperm.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mumps.out
>>>> src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_mumps_redundant.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_seqcrl.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_seqcsrperm.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex10_umfpack.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex11_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex11f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex12_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex12_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex12_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex13_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex13f90_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex14_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex14_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex15_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex15f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex16_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex18_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex1f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex20_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex20_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex21f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex22_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex23_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex23_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex25_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex25_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex26_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex28_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex29_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex29_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_4.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_5.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_6.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_7.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_bjacobi.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_bjacobi_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_bjacobi_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_specest_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_specest_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2_umfpack.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex2f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex30_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex32_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex34_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex38_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex39_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex40_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex42_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex43_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex43_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex45_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex45_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex45f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex49_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex49_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex49_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex4_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex50.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex50_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex52_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex53.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54_0.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex54f.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex55_0.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex55_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex56_0.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex58.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_4.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_5.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex5_plapack.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex6f_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex7_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex8g_1.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex8g_2.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex8g_3.out
>>>> ? src/ksp/ksp/examples/AlanTutorials20120410/output/ex9_1.out
>>>> *_hg pull_*
>>>> pulling from http://petsc.cs.iit.edu/petsc/petsc-dev
>>>> searching for changes
>>>> no changes found
>>>> _*hg update*_
>>>> 0 files updated, 0 files merged, 0 files removed, 0 files unresolved
>>>> _*hg status
>>>> *_M src/ksp/ksp/examples/tutorials/ex10.c
>>>> _*cd config/BuildSystem
>>>> hg parent*_
>>>> changeset:   2878:3d4bb7478b00
>>>> tag:         tip
>>>> user:        Barry Smith <bsmith at mcs.anl.gov>
>>>> date:        Wed Nov 07 20:34:01 2012 -0600
>>>> summary:     added support for
>>>> --with-PACKAGENAME-pkg-config[=pathtosearch]
>>>> _*hg tip*_
>>>> tag:         tip
>>>> _*hg status*_
>>>> no output
>>>> _*hg pull*_
>>>> pulling from http://petsc.cs.iit.edu/petsc/BuildSystem
>>>> no changes found
>>>> _*hg update*_
>>>> _*hg status
>>>> *_no output
>>>>> please copy/paste the output of the following commands
>>>>> hg parent
>>>>> hg tip
>>>>> hg status
>>>>> hg pull
>>>>> hg update
>>>>> hg status
>>>>> hg parent
>>>>> hg tip
>>>>> hg status
>>>>> hg pull
>>>>> hg update
>>>>> hg status
>>>>> Satish
>>>>>> Thanks for your reply, Dr. Balay.
>>>>>>         However, I do not know how to get the latest version of
>>>>>> petsc-dev
>>>>>> except
>>>>>> following http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>> |cd petsc-dev||
>>>>>> hg pull -u
>>>>>> ||make
>>>>>> Those are all what I did. Should I do something else?
>>>>>> thanks,
>>>>>> Alan
>>>>>>>> Dear folks,
>>>>>>>>         I came across an error while making a code:
>>>>>>>>         This happens after I was tying to update the petsc-dev with
>>>>>>>> some
>>>>>>>> error
>>>>>>>> message; the configure.log, error.log and make.log are attached.
>>>>>>>> I've
>>>>>>>> already
>>>>>>>> sent it to petsc-maint list. Is this makefile error related to the
>>>>>>>> fail
>>>>>>>> update?
>>>>>>>          This is a Mercurial clone
>>>>>>>             Defined "VERSION_HG" to
>>>>>>> ""85e6055943e0711fccdec2d08caeba48971d3d55""
>>>>>>>             Defined "VERSION_DATE_HG" to ""Fri Sep 23 14:46:14 2011
>>>>>>> -0700""
>>>>>>>             Defined "VERSION_BS_HG" to
>>>>>>> ""e9fd775ab2bf270a9204f7cbc33603292ac5b1d8""
>>>>>>>             Defined "VERSION_BS_DATE_HG" to ""Fri Sep 16 17:33:47
>>>>>>> 2011
>>>>>>> +0200""
>>>>>>> You don't have the latest petsc-dev. Can you pull the latest
>>>>>>> petsc-dev
>>>>>>> and
>>>>>>> retry?
>>>>>>> Satish
