[petsc-users] Fwd: error messages while updating petsc-dev
Thu Nov 8 13:33:06 CST 2012
please copy/paste the output of the following commands
hg parent
hg tip
hg status
hg pull
hg update
hg status
cd config/BuildSystem
hg parent
hg tip
hg status
hg pull
hg update
hg status
Satish
On Thu, 8 Nov 2012, Zhenglun (Alan) Wei wrote:
> Thanks for your reply, Dr. Balay.
>      However, I do not know how to get the latest version of petsc-dev except
> following http://www.mcs.anl.gov/petsc/developers/index.html
> |cd petsc-dev||
> hg pull -u
> ||./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
> ||make
> Those are all what I did. Should I do something else?
> thanks,
> Alan
> > > Dear folks,
> > >      I came across an error while making a code:
> > >   makefile:7: *** missing separator. Stop.
> > >      This happens after I was tying to update the petsc-dev with some
> > > error
> > > message; the configure.log, error.log and make.log are attached. I've
> > > already
> > > sent it to petsc-maint list. Is this makefile error related to the fail
> > > update?
> >       This is a Mercurial clone
> >          Defined "VERSION_HG" to
> > ""85e6055943e0711fccdec2d08caeba48971d3d55""
> >          Defined "VERSION_DATE_HG" to ""Fri Sep 23 14:46:14 2011 -0700""
> >          Defined "VERSION_BS_HG" to
> > ""e9fd775ab2bf270a9204f7cbc33603292ac5b1d8""
> >          Defined "VERSION_BS_DATE_HG" to ""Fri Sep 16 17:33:47 2011 +0200""
> > You don't have the latest petsc-dev. Can you pull the latest petsc-dev and
> > retry?
> > Satish
