[petsc-users] Fwd: error messages while updating petsc-dev
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Thu Nov 8 13:20:28 CST 2012
Thanks for your reply, Dr. Balay.
      However, I do not know how to get the latest version of petsc-dev
except following http://www.mcs.anl.gov/petsc/developers/index.html
|cd petsc-dev||
hg pull -u
||./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
||make
Those are all what I did. Should I do something else?
thanks,
Alan
> On Thu, 8 Nov 2012, Zhenglun (Alan) Wei wrote:
>> Dear folks,
>>      I came across an error while making a code:
>>   makefile:7: *** missing separator. Stop.
>>      This happens after I was tying to update the petsc-dev with some error
>> message; the configure.log, error.log and make.log are attached. I've already
>> sent it to petsc-maint list. Is this makefile error related to the fail
>> update?
>       This is a Mercurial clone
>          Defined "VERSION_HG" to ""85e6055943e0711fccdec2d08caeba48971d3d55""
>          Defined "VERSION_DATE_HG" to ""Fri Sep 23 14:46:14 2011 -0700""
>          Defined "VERSION_BS_HG" to ""e9fd775ab2bf270a9204f7cbc33603292ac5b1d8""
>          Defined "VERSION_BS_DATE_HG" to ""Fri Sep 16 17:33:47 2011 +0200""
> You don't have the latest petsc-dev. Can you pull the latest petsc-dev and retry?
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121108/62b0da00/attachment.html>
