[petsc-users] How to use multigrid?
Sat Nov 3 12:52:13 CDT 2012
On Sat, Nov 3, 2012 at 1:38 PM, w_ang_temp <w_ang_temp at 163.com> wrote:
> Hello, Matthew
>         I just mean that the problem that I am resolving is a finite
> element problem. The linear system of it  is true elliptic equations.
> I heared that AMG was an efficient solver, so I just want to have a try
> about AMG and find that if it is efficient.
And I meant it when I said, you MUST look it up .Next time you ask us what
AMG can do, please include
a reference for a paper in which they are attacking this problem with it
and we can help.
>         By the way, I want to confirm a conception. In my view, AMG
> itself can be a solver like gmres. It can also be used as a preconditioner
> like jacobi and is used by combining with other solver. Is it right? If it
> is right, how use AMG solver?
This is true of almost all KSP and PC objects. These are all jsut
approximate solvers.
  Matt
>         Thanks.
> Jim
> >在 2012-11-04 01:21:59,"Matthew Knepley" <knepley at gmail.com> 写道:
> ><On Sat, Nov 3, 2012 at 1:17 PM, w_ang_temp <w_ang_temp at 163.com> wrote:
>>  >At 2012-11-04 01:08:26,"Jed Brown" <jedbrown at mcs.anl.gov> wrote:
>> >1. What kind of equation are you solving? AMG is not working well if it
>> takes that many iterations.
>> >I just deal with the typical soil-water coupled geotechnical problems.
>> It is a typical finite element equation. The matrix is 30000X30000 and
>> ill-conditioned.
> >We are now at the root of your problem. Solvers do not work on
> discretizations, they work on equations. No
> >solver is designed for "finite elements", and there is no typical finite
> element problem.
> >Multigrid works best on elliptic equations with smooth coefficients.
> Without that, you have to do special things.
> >I can tell from the above discussion that you have not spent a lot of
> time researching successful preconditioning
> >strategies for your problem in the literature. This is always the first
> step to building a high performance solver.
>  > Thanks,
> >     Matt
>>  >2.
>> *      #                          WARNING!!!                    #*
>> *      #   This code was compiled with a debugging option,      #*
>> *      #   To get timing results run ./configure                #*
>> *      #   using --with-debugging=no, the performance will      #*
>> *      #   be generally two or three times faster.              #*
>> >It is true a debugging version. And I used the same version dealing with
>> the same problem, one preconditioner is asm
>> >and the other is amg. The time with amg is about 3 times as with asm. I
>> do not know the reason. And I also do not know the
>> >meaning of '[0]PCSetData_AGG bs=1 MM=7601'.
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121103/e971e292/attachment-0001.html>
