[petsc-users] stokes and fieldsplit
Fri Jun 22 15:45:55 CDT 2012
On Fri, Jun 22, 2012 at 12:15 PM, Anton Popov <popov at uni-mainz.de> wrote:
> Hi petsc team,
> I have a question about using nested matrices and vectors for coupled
> solution of Stokes system with filedsplit preconditioner.
> Is there a simple example explaining how I can create nested matrix and
> vector using
> "MatCreateNest" and "VecCreateNest" functions, provided that I already
> have all constituting blocks correctly assembled?
> I could not find these example online, and if I do it straightforwardly
> according to documentation, petsc complains that some vector blocks are not
> setup.
You do not need MatNest to use FS. Some of us have a crazy MatNest
attachment, so it seems like you do,
but it will work with any matrix.
> Do I need to define velocity and pressure splits using
> "PCFieldSplitSetIS", because if I don't, petsc says "Unhandled case, must
> have at least two fields, not 1!"?
If you really have Stokes (a 0 pressure block), use
-pc_fieldsplit_detect_saddle_point.
> Do I need to explicitly specify the blocksize, if I want to use the
> filedsplit preconditioner for the velocity block?
No.
> A small example would be extremely helpful
SNES ex62 runs it, but you need my FEM assembly configured to do that. I
will post instructions soon.
   Matt
> Thanks a lot,
> Anton
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120622/557c6386/attachment.html>
