[petsc-users] stokes and fieldsplit
Anton Popov popov at uni-mainz.de
Fri Jun 22 13:15:45 CDT 2012
Hi petsc team,
I have a question about using nested matrices and vectors for coupled
solution of Stokes system with filedsplit preconditioner.
Is there a simple example explaining how I can create nested matrix and
vector using
"MatCreateNest" and "VecCreateNest" functions, provided that I already
have all constituting blocks correctly assembled?
I could not find these example online, and if I do it straightforwardly
according to documentation, petsc complains that some vector blocks are
not setup.
Do I need to define velocity and pressure splits using
"PCFieldSplitSetIS", because if I don't, petsc says "Unhandled case,
must have at least two fields, not 1!"?
Do I need to explicitly specify the blocksize, if I want to use the
filedsplit preconditioner for the velocity block?
A small example would be extremely helpful
Thanks a lot,
Anton
