[petsc-users] Broken link for FFC
Fri Jun 15 06:03:43 CDT 2012
On Fri, Jun 15, 2012 at 5:17 AM, Ajay Rawat <ajay.rawat83 at gmail.com> wrote:
> Dear Dev
> While configuring the PETSc with --download-ffc options it throws an error
> Downloaded package FFC from:
> http://www.fenics.org/pub/software/ffc/v0.3/ffc-0.3.3.tar.gz is not a
> tarball.
> [or installed python cannot process compressed files]
This server has not existed for a while (a troll threatened legal action
over the name, IIRC). Matt will have to check whether new versions of FFC
work with his code. It's not used by "mainstream" PETSc.
> * If you are behind a firewall - please fix your proxy and rerun
> ./configure
>   For example at LANL you may need to set the environmental variable
> http_proxy (or HTTP_PROXY?) to  http://proxyout.lanl.gov
> * Alternatively, you can download the above URL manually, to
> /yourselectedlocation/ffc-0.3.3.tar.gz
>   and use the configure option:
>   --download-ffc=/yourselectedlocation/ffc-0.3.3.tar.gz
> I guess the link is not correct.
> I have one more doubt regarding ffc. I see no examples regarding how to
> use ffc inside PETSc, or it is used inside fenics.
> With regards,
> Ajay Rawat
> Kalpakkam, IGCAR
> Save Himalayas....
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120615/38b14290/attachment.html>
