[petsc-users] Broken link for FFC
Ajay Rawat ajay.rawat83 at gmail.com
Fri Jun 15 05:17:40 CDT 2012
Dear Dev
While configuring the PETSc with --download-ffc options it throws an error
Downloaded package FFC from:
http://www.fenics.org/pub/software/ffc/v0.3/ffc-0.3.3.tar.gz is not a
tarball.
[or installed python cannot process compressed files]
* If you are behind a firewall - please fix your proxy and rerun ./configure
  For example at LANL you may need to set the environmental variable
http_proxy (or HTTP_PROXY?) to  http://proxyout.lanl.gov
* Alternatively, you can download the above URL manually, to
/yourselectedlocation/ffc-0.3.3.tar.gz
  and use the configure option:
  --download-ffc=/yourselectedlocation/ffc-0.3.3.tar.gz
I guess the link is not correct.
I have one more doubt regarding ffc. I see no examples regarding how to use
ffc inside PETSc, or it is used inside fenics.
With regards,
Ajay Rawat
Kalpakkam, IGCAR
Save Himalayas....
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120615/2b341e62/attachment.html>
