[petsc-users] Computation to communication ratio for PETSc's routines
Thu Jun 14 06:14:57 CDT 2012
On Thu, Jun 14, 2012 at 3:09 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jun 13, 2012, at 8:17 AM, Alexander Grayver wrote:
> > On 13.06.2012 13:24, Matthew Knepley wrote:
> >> On Wed, Jun 13, 2012 at 6:45 PM, Alexander Grayver <
> agrayver at gfz-potsdam.de> wrote:
> >> Hello,
> >> As stated, I would like to estimate computation to communication ratio
> for PETSc's linear algebra routines (e.g. MatMult{Transpose}, MatPtAP,
> MatMatMult etc.)
> >> As far as I understand the ratio depends on particular implementation
> and number of processes one runs application on.
> >> So I guess these formulas should be known?
> >> It depends on the input data. For example, block diagonal matrices do
> not communicate in MatMult().
> >> If not then I see one way to estimate it. Write app with those
> operations, parse -log_summary and then divide flops/messages, however the
> question is what information from -log_summary output should be used for
> that?
> >> We give the number of messages and the average message length, so you
> can get the total length across processes. Since
> >> each side records, we divide by 2 (I think, you should check
> PetscLogView for specifics). You can also use PetscLogViewPython()
> >> to simplify parsing.
> > Is there total amount of flops given for different operations separately
> (I see max flops over all processes only)?
>    Sadly no. My original plan was that people who wanted different summary
> information would copy PetscLogView() and modify it to output just what
> they want. Sadly that may be too difficult.
You can back out the total flops from the flop rate and time.
   Matt
>   Barry
> >>    Matt
> >> Thanks.
> >> Regards,
> >> Alexander
> >> What most experimenters take for granted before they begin their
> experiments lead.
> >> -- Norbert Wiener
> > Regards,
> > Alexander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120614/c4d140a5/attachment.html>
