[petsc-users] petsc dev mat assembly fails
Sun Jun 3 08:19:08 CDT 2012
On Sun, Jun 3, 2012 at 7:44 AM, Wen Jiang <jiangwen84 at gmail.com> wrote:
> Hi,
> I switched my code from petsc 3.2 to petsc dev in order to use the newest
> superlu dist. And I also change MatCreateMPIAIJ to MatCreateAIJ as
> mentioned on developer site. However I got some errors which I did not have
> in petsc 3.2. From tracking the -info output, I found my code did not
> execute the MatAssembly correctly. The output file is attached. Thus I am
> wondering what else I should pay attention to when switching from 3.2 to
> dev. Thanks.
There aren't any errors in this -info output? What did you see? Send the
whole error message.
> Regards,
> Wen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120603/8b0d19d5/attachment.html>
