[petsc-users] petsc dev mat assembly fails
Wen Jiang jiangwen84 at gmail.com
Sun Jun 3 07:44:39 CDT 2012
I switched my code from petsc 3.2 to petsc dev in order to use the newest
superlu dist. And I also change MatCreateMPIAIJ to MatCreateAIJ as
mentioned on developer site. However I got some errors which I did not have
in petsc 3.2. From tracking the -info output, I found my code did not
execute the MatAssembly correctly. The output file is attached. Thus I am
wondering what else I should pay attention to when switching from 3.2 to
dev. Thanks.
Wen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120603/6aab6905/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120603/6aab6905/attachment-0001.obj>
