[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
Sun Jan 29 13:29:47 CST 2012
On Sun, Jan 29, 2012 at 1:24 PM, recrusader <recrusader at gmail.com> wrote:
> I have thought I send this question to CUSP mailing list. Therefore, I
> wish I could get the same errors using the simple codes. However, the
> errors disappear.
The code below has no PETSc library calls. I really do not understand what
you are asking.
Can you run a simple PETSc example with the GPU?
  cd src/snes/examples/tutorials
  make ex5
  ./ex5 -vec_type cusp -log_summary
  Matt
> Is it possible to provide simple codes with PETSc to show the errors?
> Thanks again.
> Best,
> Yujie
> On Sun, Jan 29, 2012 at 1:20 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Jan 29, 2012 at 1:05 PM, recrusader <recrusader at gmail.com> wrote:
>>> Thank you very much, Matt,
>>> You mean the headers of the simple codes, I further simply the codes as
>> This is a question for the CUSP mailing list.
>>   Thanks,
>>      Matt
>>> #include <cusp/blas.h>
>>> #include <cusp/array1d.h>
>>> int main(void)
>>>    cusp::array1d<std::complex<double>, cusp::host_memory> *x;
>>>    x=new cusp::array1d<std::complex<double>, cusp::host_memory>(2,0.0);
>>>    std::complex<double> alpha(1,2.0);
>>>    cusp::blas::scal(*x,alpha);
>>>    return 0;
>>> I got the same compilation results "
>>> login1$ nvcc gputest.cu -o gputest
>>> /opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
>>> warning: calling a __host__ function from a __host__ __device__
>>> function is not allowed
>>>          detected during:
>>>            instantiation of "void
>>> cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
>>> T=std::complex<double>, T2=std::complex<double>]"
>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37):
>>> here
>>>            instantiation of "InputIterator
>>> thrust::detail::host::for_each(InputIterator, InputIterator,
>>> UnaryFunction) [with
>>> InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
>>> UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
>>> here
>>> thrust::detail::dispatch::for_each(InputIterator, InputIterator,
>>> UnaryFunction, thrust::host_space_tag) [with
>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51):
>>> here
>>> thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
>>> [with InputIterator=thrust::detail::normal_iterator<std::complex<double>
>>> *>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67):
>>> here
>>>            instantiation of "void thrust::for_each(InputIterator,
>>> InputIterator, UnaryFunction) [with
>>> (367): here
>>> cusp::blas::detail::scal(ForwardIterator, ForwardIterator, ScalarType)
>>> [with
>>> ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
>>> *>, ScalarType=std::complex<double>]"
>>> (748): here
>>>            instantiation of "void cusp::blas::scal(Array &,
>>> ScalarType) [with Array=cusp::array1d<std::complex<double>,
>>> cusp::host_memory>, ScalarType=std::complex<double>]"
>>> gputest.cu(25): here
>>> Thanks a lot.
>>> Best,
>>> Yujie
>>> On 1/29/12, Matthew Knepley <knepley at gmail.com> wrote:
>>> > On Sun, Jan 29, 2012 at 12:53 PM, recrusader <recrusader at gmail.com>
>>> wrote:
>>> >> Dear PETSc developers,
>>> >> With your help, I can successfully PETSc-deve with enabling GPU and
>>> >> complex number.
>>> >> However, when I compiled the codes, I met some errors. I also tried to
>>> >> use simple codes to realize the same function. However, the errors
>>> >> disappear. One example is as follows:
>>> >> for the function "VecScale_SeqCUSP"
>>> >> "#undef __FUNCT__
>>> >> #define __FUNCT__ "VecScale_SeqCUSP"
>>> >> PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
>>> >>  CUSPARRAY      *xarray;
>>> >>  PetscErrorCode ierr;
>>> >>  PetscFunctionBegin;
>>> >>  if (alpha == 0.0) {
>>> >>    ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
>>> >>  } else if (alpha != 1.0) {
>>> >>    ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>> >>    try {
>>> >>      cusp::blas::scal(*xarray,alpha);
>>> >>    } catch(char* ex) {
>>> >>      SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
>>> >>    ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>>> >>  ierr = WaitForGPU();CHKERRCUSP(ierr);
>>> >>  ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
>>> >>  PetscFunctionReturn(0);
>>> >> When I compiled PETSc-dev, I met the following errors:
>>> >> " /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134): warning:
>>> >> calling a __host__ function from a __host__ __device__ function is not
>>> >> allowed
>>> >>          detected during:
>>> >> T=std::complex<double>, T2=PetscScalar]"
>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72):
>>> >> here
>>> >> thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
>>> >> Size, UnaryFunction>::operator()() [with
>>> RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>> >> Size=long,
>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>> >> here
>>> thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
>>> >> [with
>>> NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>]"
>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
>>> >> here
>>> >>            instantiation of "size_t
>>> thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
>>> >> launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>,
>>> >> launch_by_value=true]"
>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
>>> >> here
>>> >>            instantiation of "thrust::pair<size_t, size_t>
>>> thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
>>> >> [with
>>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
>>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
>>> >> here
>>> >>            [ 6 instantiation contexts not shown ]
>>> >> UnaryFunction, thrust::device_space_tag) [with
>>> InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51): here
>>> >> [with
>>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67): here
>>> >> (367): here
>>> >> [with
>>> ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>>> >> (748): here
>>> >> ScalarType) [with Array=cusp::array1d<PetscScalar,
>>> >> cusp::device_memory>, ScalarType=std::complex<double>]"
>>> >> veccusp.cu(1185): here
>>> >> error: a value of type "int" cannot be assigned to an entity of type
>>> >> "_ZNSt7complexIdE9_ComplexTE"
>>> >> However, I further realize simiar codes as
>>> >> #include <thrust/version.h>
>>> >> #include <cusp/version.h>
>>> >> #include <iostream>
>>> >> #include <complex>
>>> >> int main(void)
>>> >>    return 0;
>>> >> When I complied it using  "nvcc gputest.cu -o gputest", I only meet
>>> >> warning information as follows:
>>> >>          detected during:
>>> >> here
>>> >> here
>>> >> here
>>> >> [with
>>> >> here
>>> >> (367): here
>>> >> [with
>>> >> (748): here
>>> >> There are not errors like
>>> "/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>>> >> "_ZNSt7complexIdE9_ComplexTE" "
>>> >> Furthermore, the warning information is also different between
>>> >> PETSc-dev and simple codes.
>>> >> Could you give me some suggestion for this errors? Thank you very
>>> much.
>>> > The headers are complicated to get right. The whole point of what we
>>> did is
>>> > to give a way to use GPU
>>> > simply through the existing PETSc linear algebra interface.
>>> >    Matt
>>> >> Best,
>>> >> Yujie
>>> > What most experimenters take for granted before they begin their
>>> > experiments is infinitely more interesting than any results to which
>>> their
>>> > experiments lead.
>>> > -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120129/9b7ed0ed/attachment.htm>
