[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
recrusader recrusader at gmail.com
Sun Jan 29 13:24:30 CST 2012
I have thought I send this question to CUSP mailing list. Therefore, I wish
I could get the same errors using the simple codes. However, the errors
disappear.
Is it possible to provide simple codes with PETSc to show the errors?
Thanks again.
Best,
Yujie
On Sun, Jan 29, 2012 at 1:20 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Jan 29, 2012 at 1:05 PM, recrusader <recrusader at gmail.com> wrote:
>> Thank you very much, Matt,
>> You mean the headers of the simple codes, I further simply the codes as
> This is a question for the CUSP mailing list.
>   Thanks,
>      Matt
>> #include <cusp/blas.h>
>> #include <cusp/array1d.h>
>> int main(void)
>>    cusp::array1d<std::complex<double>, cusp::host_memory> *x;
>>    x=new cusp::array1d<std::complex<double>, cusp::host_memory>(2,0.0);
>>    std::complex<double> alpha(1,2.0);
>>    cusp::blas::scal(*x,alpha);
>>    return 0;
>> I got the same compilation results "
>> login1$ nvcc gputest.cu -o gputest
>> /opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
>> warning: calling a __host__ function from a __host__ __device__
>> function is not allowed
>>          detected during:
>>            instantiation of "void
>> cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
>> T=std::complex<double>, T2=std::complex<double>]"
>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37):
>> here
>>            instantiation of "InputIterator
>> thrust::detail::host::for_each(InputIterator, InputIterator,
>> UnaryFunction) [with
>> InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
>> UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
>> here
>> thrust::detail::dispatch::for_each(InputIterator, InputIterator,
>> UnaryFunction, thrust::host_space_tag) [with
>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51):
>> here
>> thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
>> [with InputIterator=thrust::detail::normal_iterator<std::complex<double>
>> *>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
>> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67):
>> here
>>            instantiation of "void thrust::for_each(InputIterator,
>> InputIterator, UnaryFunction) [with
>> (367): here
>> cusp::blas::detail::scal(ForwardIterator, ForwardIterator, ScalarType)
>> [with ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
>> *>, ScalarType=std::complex<double>]"
>> (748): here
>>            instantiation of "void cusp::blas::scal(Array &,
>> ScalarType) [with Array=cusp::array1d<std::complex<double>,
>> cusp::host_memory>, ScalarType=std::complex<double>]"
>> gputest.cu(25): here
>> Thanks a lot.
>> Best,
>> Yujie
>> On 1/29/12, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Sun, Jan 29, 2012 at 12:53 PM, recrusader <recrusader at gmail.com>
>> wrote:
>> >> Dear PETSc developers,
>> >> With your help, I can successfully PETSc-deve with enabling GPU and
>> >> complex number.
>> >> However, when I compiled the codes, I met some errors. I also tried to
>> >> use simple codes to realize the same function. However, the errors
>> >> disappear. One example is as follows:
>> >> for the function "VecScale_SeqCUSP"
>> >> "#undef __FUNCT__
>> >> #define __FUNCT__ "VecScale_SeqCUSP"
>> >> PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
>> >>  CUSPARRAY      *xarray;
>> >>  PetscErrorCode ierr;
>> >>  PetscFunctionBegin;
>> >>  if (alpha == 0.0) {
>> >>    ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
>> >>  } else if (alpha != 1.0) {
>> >>    ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>> >>    try {
>> >>      cusp::blas::scal(*xarray,alpha);
>> >>    } catch(char* ex) {
>> >>      SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
>> >>    ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>> >>  ierr = WaitForGPU();CHKERRCUSP(ierr);
>> >>  ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
>> >>  PetscFunctionReturn(0);
>> >> When I compiled PETSc-dev, I met the following errors:
>> >> " /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134): warning:
>> >> calling a __host__ function from a __host__ __device__ function is not
>> >> allowed
>> >>          detected during:
>> >> T=std::complex<double>, T2=PetscScalar]"
>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72):
>> >> here
>> >> thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
>> >> Size, UnaryFunction>::operator()() [with
>> RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>> >> Size=long,
>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>> >> here
>> thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
>> >> [with
>> NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>]"
>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
>> >> here
>> >>            instantiation of "size_t
>> thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
>> >> launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>,
>> >> launch_by_value=true]"
>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
>> >> here
>> >>            instantiation of "thrust::pair<size_t, size_t>
>> thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
>> >> [with
>> >> long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
>> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
>> >> here
>> >>            [ 6 instantiation contexts not shown ]
>> >> UnaryFunction, thrust::device_space_tag) [with
>> InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51): here
>> >> [with
>> >> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67): here
>> >> (367): here
>> >> [with
>> ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
>> >> (748): here
>> >> ScalarType) [with Array=cusp::array1d<PetscScalar,
>> >> cusp::device_memory>, ScalarType=std::complex<double>]"
>> >> veccusp.cu(1185): here
>> >> error: a value of type "int" cannot be assigned to an entity of type
>> >> "_ZNSt7complexIdE9_ComplexTE"
>> >> However, I further realize simiar codes as
>> >> #include <thrust/version.h>
>> >> #include <cusp/version.h>
>> >> #include <iostream>
>> >> #include <complex>
>> >> int main(void)
>> >>    return 0;
>> >> When I complied it using  "nvcc gputest.cu -o gputest", I only meet
>> >> warning information as follows:
>> >>          detected during:
>> >> here
>> >> here
>> >> here
>> >> [with
>> >> here
>> >> (367): here
>> >> [with
>> >> (748): here
>> >> There are not errors like
>> "/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
>> >> "_ZNSt7complexIdE9_ComplexTE" "
>> >> Furthermore, the warning information is also different between
>> >> PETSc-dev and simple codes.
>> >> Could you give me some suggestion for this errors? Thank you very much.
>> > The headers are complicated to get right. The whole point of what we
>> did is
>> > to give a way to use GPU
>> > simply through the existing PETSc linear algebra interface.
>> >    Matt
>> >> Best,
>> >> Yujie
>> > What most experimenters take for granted before they begin their
>> > experiments is infinitely more interesting than any results to which
>> their
>> > experiments lead.
>> > -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120129/1511d75c/attachment-0001.htm>
