[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
Sun Jan 29 13:00:43 CST 2012
On Sun, Jan 29, 2012 at 12:53 PM, recrusader <recrusader at gmail.com> wrote:
> Dear PETSc developers,
> With your help, I can successfully PETSc-deve with enabling GPU and
> complex number.
> However, when I compiled the codes, I met some errors. I also tried to
> use simple codes to realize the same function. However, the errors
> disappear. One example is as follows:
> for the function "VecScale_SeqCUSP"
> "#undef __FUNCT__
> #define __FUNCT__ "VecScale_SeqCUSP"
> PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
>  CUSPARRAY      *xarray;
>  PetscErrorCode ierr;
>  PetscFunctionBegin;
>  if (alpha == 0.0) {
>    ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
>  } else if (alpha != 1.0) {
>    ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>    try {
>      cusp::blas::scal(*xarray,alpha);
>    } catch(char* ex) {
>      SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
>    ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
>  ierr = WaitForGPU();CHKERRCUSP(ierr);
>  ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
>  PetscFunctionReturn(0);
> When I compiled PETSc-dev, I met the following errors:
> " /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134): warning:
> calling a __host__ function from a __host__ __device__ function is not
> allowed
>          detected during:
>            instantiation of "void
> cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
> T=std::complex<double>, T2=PetscScalar]"
> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72):
> here
> thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
> Size, UnaryFunction>::operator()() [with
> RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
> Size=long, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
> here
> thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
> [with
> NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
> long, cusp::blas::detail::SCAL<std::complex<double>>>]"
> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
> here
>            instantiation of "size_t
> thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
> launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
> long, cusp::blas::detail::SCAL<std::complex<double>>>,
> launch_by_value=true]"
> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
> here
>            instantiation of "thrust::pair<size_t, size_t>
> thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
> [with
> long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
> /opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
> here
>            [ 6 instantiation contexts not shown ]
>            instantiation of "InputIterator
> thrust::detail::dispatch::for_each(InputIterator, InputIterator,
> UnaryFunction, thrust::device_space_tag) [with
> InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51): here
> thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
> [with
> /opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67): here
>            instantiation of "void thrust::for_each(InputIterator,
> InputIterator, UnaryFunction) [with
> (367): here
> cusp::blas::detail::scal(ForwardIterator, ForwardIterator, ScalarType)
> [with
> ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
> ScalarType=std::complex<double>]"
> (748): here
>            instantiation of "void cusp::blas::scal(Array &,
> ScalarType) [with Array=cusp::array1d<PetscScalar,
> cusp::device_memory>, ScalarType=std::complex<double>]"
> veccusp.cu(1185): here
> error: a value of type "int" cannot be assigned to an entity of type
> "_ZNSt7complexIdE9_ComplexTE"
> However, I further realize simiar codes as
> #include <thrust/version.h>
> #include <cusp/version.h>
> #include <iostream>
> #include <cusp/blas.h>
> #include <cusp/array1d.h>
> #include <complex>
> int main(void)
>    cusp::array1d<std::complex<double>, cusp::host_memory> *x;
>    x=new cusp::array1d<std::complex<double>, cusp::host_memory>(2,0.0);
>    std::complex<double> alpha(1,2.0);
>    cusp::blas::scal(*x,alpha);
>    return 0;
> When I complied it using  "nvcc gputest.cu -o gputest", I only meet
> warning information as follows:
> /opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
> warning: calling a __host__ function from a __host__ __device__
> function is not allowed
>          detected during:
> T=std::complex<double>, T2=std::complex<double>]"
> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37):
> here
> thrust::detail::host::for_each(InputIterator, InputIterator,
> InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
> here
> UnaryFunction, thrust::host_space_tag) [with
> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51): here
> [with InputIterator=thrust::detail::normal_iterator<std::complex<double>
> *>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
> /opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67): here
> (367): here
> [with ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
> *>, ScalarType=std::complex<double>]"
> (748): here
> ScalarType) [with Array=cusp::array1d<std::complex<double>,
> cusp::host_memory>, ScalarType=std::complex<double>]"
> gputest.cu(25): here
> There are not errors like
> "/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
> "_ZNSt7complexIdE9_ComplexTE" "
> Furthermore, the warning information is also different between
> PETSc-dev and simple codes.
> Could you give me some suggestion for this errors? Thank you very much.
The headers are complicated to get right. The whole point of what we did is
to give a way to use GPU
simply through the existing PETSc linear algebra interface.
   Matt
> Best,
> Yujie
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120129/c3c7d62a/attachment.htm>
