[petsc-users] one compilation error in PETSc-dev with enabling GPU and complex number
recrusader recrusader at gmail.com
Sun Jan 29 12:53:23 CST 2012
Dear PETSc developers,
With your help, I can successfully PETSc-deve with enabling GPU and
complex number.
However, when I compiled the codes, I met some errors. I also tried to
use simple codes to realize the same function. However, the errors
disappear. One example is as follows:
for the function "VecScale_SeqCUSP"
"#undef __FUNCT__
#define __FUNCT__ "VecScale_SeqCUSP"
PetscErrorCode VecScale_SeqCUSP(Vec xin, PetscScalar alpha)
  CUSPARRAY      *xarray;
  PetscErrorCode ierr;
  PetscFunctionBegin;
  if (alpha == 0.0) {
    ierr = VecSet_SeqCUSP(xin,alpha);CHKERRQ(ierr);
  } else if (alpha != 1.0) {
    ierr = VecCUSPGetArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
    try {
      cusp::blas::scal(*xarray,alpha);
    } catch(char* ex) {
      SETERRQ1(PETSC_COMM_SELF,PETSC_ERR_LIB,"CUSP error: %s", ex);
    ierr = VecCUSPRestoreArrayReadWrite(xin,&xarray);CHKERRQ(ierr);
  ierr = WaitForGPU();CHKERRCUSP(ierr);
  ierr = PetscLogFlops(xin->map->n);CHKERRQ(ierr);
  PetscFunctionReturn(0);
When I compiled PETSc-dev, I met the following errors:
" /opt/apps/cuda/4.0/cuda/include/cusp/detail/blas.inl(134): warning:
calling a __host__ function from a __host__ __device__ function is not
allowed
          detected during:
            instantiation of "void
cusp::blas::detail::SCAL<T>::operator()(T2 &) [with
T=std::complex<double>, T2=PetscScalar]"
/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/for_each.inl(72): here
thrust::detail::device::cuda::for_each_n_closure<RandomAccessIterator,
Size, UnaryFunction>::operator()() [with
RandomAccessIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
Size=long, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
here
thrust::detail::device::cuda::detail::launch_closure_by_value(NullaryFunction)
[with NullaryFunction=thrust::detail::device::cuda::for_each_n_closure<thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
long, cusp::blas::detail::SCAL<std::complex<double>>>]"
/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(71):
here
            instantiation of "size_t
thrust::detail::device::cuda::detail::closure_launcher_base<NullaryFunction,
launch_by_value>::block_size_with_maximal_occupancy(size_t) [with
long, cusp::blas::detail::SCAL<std::complex<double>>>,
launch_by_value=true]"
/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(136):
here
            instantiation of "thrust::pair<size_t, size_t>
thrust::detail::device::cuda::detail::closure_launcher<NullaryFunction>::configuration_with_maximal_occupancy(Size)
long, cusp::blas::detail::SCAL<std::complex<double>>>, Size=long]"
/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(145):
here
            [ 6 instantiation contexts not shown ]
            instantiation of "InputIterator
thrust::detail::dispatch::for_each(InputIterator, InputIterator,
UnaryFunction, thrust::device_space_tag) [with
InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
/opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(51): here
thrust::detail::for_each(InputIterator, InputIterator, UnaryFunction)
[with InputIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
/opt/apps/cuda/4.0/cuda/include/thrust/detail/for_each.inl(67): here
            instantiation of "void thrust::for_each(InputIterator,
InputIterator, UnaryFunction) [with
(367): here
cusp::blas::detail::scal(ForwardIterator, ForwardIterator, ScalarType)
[with ForwardIterator=thrust::detail::normal_iterator<thrust::device_ptr<PetscScalar>>,
ScalarType=std::complex<double>]"
(748): here
            instantiation of "void cusp::blas::scal(Array &,
ScalarType) [with Array=cusp::array1d<PetscScalar,
cusp::device_memory>, ScalarType=std::complex<double>]"
veccusp.cu(1185): here
error: a value of type "int" cannot be assigned to an entity of type
"_ZNSt7complexIdE9_ComplexTE"
However, I further realize simiar codes as
#include <thrust/version.h>
#include <cusp/version.h>
#include <iostream>
#include <cusp/blas.h>
#include <cusp/array1d.h>
#include <complex>
int main(void)
    cusp::array1d<std::complex<double>, cusp::host_memory> *x;
    x=new cusp::array1d<std::complex<double>, cusp::host_memory>(2,0.0);
    std::complex<double> alpha(1,2.0);
    cusp::blas::scal(*x,alpha);
    return 0;
When I complied it using  "nvcc gputest.cu -o gputest", I only meet
warning information as follows:
/opt/apps/cuda/4.0/cuda/bin/../include/cusp/detail/blas.inl(134):
warning: calling a __host__ function from a __host__ __device__
function is not allowed
          detected during:
T=std::complex<double>, T2=std::complex<double>]"
/opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/host/for_each.inl(37): here
thrust::detail::host::for_each(InputIterator, InputIterator,
InputIterator=thrust::detail::normal_iterator<std::complex<double> *>,
/opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/dispatch/for_each.h(46):
here
UnaryFunction, thrust::host_space_tag) [with
/opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(51): here
[with InputIterator=thrust::detail::normal_iterator<std::complex<double>
*>, UnaryFunction=cusp::blas::detail::SCAL<std::complex<double>>]"
/opt/apps/cuda/4.0/cuda/bin/../include/thrust/detail/for_each.inl(67): here
(367): here
[with ForwardIterator=thrust::detail::normal_iterator<std::complex<double>
*>, ScalarType=std::complex<double>]"
(748): here
ScalarType) [with Array=cusp::array1d<std::complex<double>,
cusp::host_memory>, ScalarType=std::complex<double>]"
gputest.cu(25): here
There are not errors like
"/opt/apps/cuda/4.0/cuda/include/thrust/detail/device/cuda/detail/launch_closure.inl(51):
"_ZNSt7complexIdE9_ComplexTE" "
Furthermore, the warning information is also different between
PETSc-dev and simple codes.
Could you give me some suggestion for this errors? Thank you very much.
Best,
Yujie
