[petsc-users] MatConvert behavior 3.1 vs 3.2
Fri Jan 27 08:54:59 CST 2012
On Fri, 27 Jan 2012, Dominik Szczerba wrote:
> >> Immediately one suggestion: it would be nice to pull and build the
> >> external packages at option separately from the rest of petsc.
> > ??? petsc configure already does this for you..
> > [you don't have to build PETSc - after externalpacakges are built...]
> But it breaks...
what breaks? Send relavent logs to petsc-maint.
>  As I wrote above, I can fix it,
don't understand what the problme is - so don't understand what your fix is.
> but then re-running configure rebuilds my built version.
thats fine.
> Then I tried --with instead of --download, that resulted in a correct
> build,
again - don't know what the problem is - so don't understand this workarround.
> unfortunately, seems like parmetis is somehow not registered
> with petsc:
> [0]PETSC ERROR: Unknown partitioning type parmetis!
> Would you please advise how to go on?
start with the original problem - and send logs [not logs with workarrounds]
satish
> Thanks
> Dominik
