[petsc-users] MatConvert behavior 3.1 vs 3.2
Dominik Szczerba dominik at itis.ethz.ch
Fri Jan 27 08:51:36 CST 2012
>> Immediately one suggestion: it would be nice to pull and build the
>> external packages at option separately from the rest of petsc.
> ??? petsc configure already does this for you..
> [you don't have to build PETSc - after externalpacakges are built...]
But it breaks... As I wrote above, I can fix it, but then re-running
configure rebuilds my built version.
Then I tried --with instead of --download, that resulted in a correct
build, unfortunately, seems like parmetis is somehow not registered
with petsc:
[0]PETSC ERROR: Unknown partitioning type parmetis!
Would you please advise how to go on?
Thanks
Dominik
