[petsc-users] SNESVI convergence spped
Ataollah Mesgarnejad amesga1 at tigers.lsu.edu
Wed Jan 25 08:55:39 CST 2012
Barry,
Here is my output from my program  with petsc-dev (txt files attached). Even with petsc-dev (revision 21929), SNES (I tried VISS and VIRS) takes a long time to converge (>50 iterations) from a small problem (99 HEX20 elements, 681 DOFs for SNES). The exodusII output files are uploaded in the link; I attached pictures of last time step for Psi field which we solve with SNESVI and u field which the displacement in the x-direction and is my loading.  As it was the case with petsc-3.2 line search diverges as soon as we hit the lower bound in a neighborhood of nodes. I ran with KSPPREONLY and PCLU to exclude possibility of LS failure because of the KSP tol.
Best,
Ata
link to exodusII files: http://cl.ly/0g431o443v240x1h2h1B
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120125/937250a8/attachment-0002.txt>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120125/937250a8/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120125/937250a8/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120125/937250a8/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120125/937250a8/attachment-0007.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120125/937250a8/attachment-0003.txt>
