[petsc-users] CUDA with complex number
Paul Mullowney paulm at txcorp.com
Mon Jan 23 15:28:44 CST 2012
I would claim that Petsc does not support GPU capabilities for complex
numbers right now.
The CUSP library is templated over the scalar type (i.e. float or
double), however I don't think it supports complex numbers. Although, I
could be wrong on this.
It could be somewhat straightforward to move from CUSP to CUSPARSE (yes,
these are different Nvidia libraries). I believe CUSPARSE supports SpMV
for complex types. It also supports triangular solve for complex types.
-Paul
>      This is an installation issue, please send all installation issues to petsc-maint at mcs.anl.gov with the entire configure.log
>     You can try editing config/PETSc/packages/cuda.py and removing the two lines
>      if self.scalartypes.scalartype == 'complex':
>        raise RuntimeError('Must use real numbers with CUDA')
>     As it says we have never tested for complex so I do not know how far it is from working.
>      Barry
> On Jan 23, 2012, at 1:24 PM, recrusader wrote:
>> Dear PETSc Developers,
>> I am compiling PETSc-dev using GPU in complex number mode.
>> However, when I configure PETSc-dev, I get the following errors
>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>> for details):
>> Cannot use cuda with complex numbers it is not coded for this capability
>> I have checked CUSP. The latest version can support complex number.
>> What should I do for CUDA?
>> Thank you very much.
>> Best,
>> Yujie
