[petsc-users] CUDA with complex number
Mon Jan 23 15:23:19 CST 2012
    This is an installation issue, please send all installation issues to petsc-maint at mcs.anl.gov with the entire configure.log
   You can try editing config/PETSc/packages/cuda.py and removing the two lines
    if self.scalartypes.scalartype == 'complex':
      raise RuntimeError('Must use real numbers with CUDA')
   As it says we have never tested for complex so I do not know how far it is from working.
    Barry
On Jan 23, 2012, at 1:24 PM, recrusader wrote:
> Dear PETSc Developers,
> I am compiling PETSc-dev using GPU in complex number mode.
> However, when I configure PETSc-dev, I get the following errors
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> Cannot use cuda with complex numbers it is not coded for this capability
> I have checked CUSP. The latest version can support complex number.
> What should I do for CUDA?
> Thank you very much.
> Best,
> Yujie
