[petsc-users] problems compiling
Fri Jan 20 09:49:13 CST 2012
   Dominik,
     Come on, you know better. All installation problems got to petsc-maint at mcs.anl.gov ONLY and ALWAYS send the configure.log
   Barry
On Jan 20, 2012, at 9:43 AM, Dominik Szczerba wrote:
> I am building on a Cray system with crayftn fortran compiler. I
> specify --with-fc=crayftn and --FFLAGS=-em. Despite the latter, I am
> still getting the below cited error. Interestingly, the mod file IS
> THERE:
>> find /tmp/petsc-0Bnd1w -iname \*.mod
> /tmp/petsc-0Bnd1w/config.compilers/CONFIGTEST.mod
> How do I go on from here?
> Thanks
> Dominik
> TEST checkFortranModuleInclude from
> config.compilers(/users/dsz/pack/petsc-3.2-p5/config/BuildSystem/config/compilers.py:1155)
> TESTING: checkFortranModuleInclude from
> config.compilers(config/BuildSystem/config/compilers.py:1155)
>  Figures out what flag is used to specify the include path for Fortran modules
>        Pushing language FC
> sh: crayftn -c -o /tmp/petsc-0Bnd1w/config.compilers/conftest.o
> -I/tmp/petsc-0Bnd1w/config.compilers
> -I/tmp/petsc-0Bnd1w/config.setCompilers -em -O3
> /tmp/petsc-0Bnd1w/config.compilers/conftest.F
> Executing: crayftn -c -o /tmp/petsc-0Bnd1w/config.compilers/conftest.o
> sh:
> Successful compile:
> Source:
>      module configtest
>      integer testint
>      parameter (testint = 42)
>      end module configtest
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> Fortran module was not created during the compile.
> configtest.mod/CONFIGTEST.mod not found
>  File "/users/dsz/pack/petsc-3.2-p5/config/configure.py", line 283,
> in petsc_configure
>    framework.configure(out = sys.stdout)
>  File "/users/dsz/pack/petsc-3.2-p5/config/BuildSystem/config/framework.py",
> line 925, in configure
>    child.configure()
>  File "/users/dsz/pack/petsc-3.2-p5/config/BuildSystem/config/compilers.py",
> line 1338, in configure
>    self.executeTest(self.checkFortranModuleInclude)
>  File "/users/dsz/pack/petsc-3.2-p5/config/BuildSystem/config/base.py",
> line 115, in executeTest
>    ret = apply(test, args,kargs)
> line 1187, in checkFortranModuleInclude
>    raise RuntimeError('Fortran module was not created during the
> compile. configtest.mod/CONFIGTEST.mod not found')
