[petsc-users] generate entries on 'wrong' process
Wen Jiang jiangwen84 at gmail.com
Fri Jan 20 09:44:13 CST 2012
Hi Barry,
Thanks for your suggestion. I just added MatSetOption(mat,
MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE) to my code, but I did not get
any error information regarding to bad allocation. And my code is stuck
there. I attached the output file below. Thanks.
[0] VecAssemblyBegin_MPI(): Stash has 210720 entries, uses 12 mallocs.
[0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
[5] MatAssemblyBegin_MPIAIJ(): Stash has 4806656 entries, uses 8 mallocs.
[6] MatAssemblyBegin_MPIAIJ(): Stash has 5727744 entries, uses 9 mallocs.
[4] MatAssemblyBegin_MPIAIJ(): Stash has 5964288 entries, uses 9 mallocs.
[7] MatAssemblyBegin_MPIAIJ(): Stash has 7408128 entries, uses 9 mallocs.
[3] MatAssemblyBegin_MPIAIJ(): Stash has 8123904 entries, uses 9 mallocs.
[2] MatAssemblyBegin_MPIAIJ(): Stash has 11544576 entries, uses 10 mallocs.
[0] MatStashScatterBegin_Private(): No of messages: 1
[0] MatStashScatterBegin_Private(): Mesg_to: 1: size: 107888648
[0] MatAssemblyBegin_MPIAIJ(): Stash has 13486080 entries, uses 10 mallocs.
[1] MatAssemblyBegin_MPIAIJ(): Stash has 16386048 entries, uses 10 mallocs.
[7] MatAssemblyEnd_SeqAIJ(): Matrix size: 11390 X 11390; storage space: 0
unneeded,2514194 used
[7] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[7] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[7] Mat_CheckInode(): Found 11390 nodes out of 11390 rows. Not using Inode
routines
[7] PetscCommDuplicate(): Using internal PETSc communicator 47582902893600
339106512
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
unneeded,2514537 used
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[0] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
[0] PetscCommDuplicate(): Using internal PETSc communicator 46968795675680
536030192
[0] MatSetUpMultiply_MPIAIJ(): Using block index set to define scatter
[6] MatAssemblyEnd_SeqAIJ(): Matrix size: 11390 X 11390; storage space: 0
unneeded,2499938 used
[6] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[6] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[6] Mat_CheckInode(): Found 11390 nodes out of 11390 rows. Not using Inode
routines
[6] PetscCommDuplicate(): Using internal PETSc communicator 47399146302496
509504096
[5] MatAssemblyEnd_SeqAIJ(): Matrix size: 11390 X 11390; storage space: 0
unneeded,2525390 used
[5] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[5] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[5] Mat_CheckInode(): Found 11390 nodes out of 11390 rows. Not using Inode
routines
[5] PetscCommDuplicate(): Using internal PETSc communicator 47033309994016
520223440
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
unneeded,2500281 used
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[1] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
[1] PetscCommDuplicate(): Using internal PETSc communicator 47149241441312
163068544
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 11391 X 11391; storage space: 0
unneeded,2525733 used
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 294
[2] Mat_CheckInode(): Found 11391 nodes out of 11391 rows. Not using Inode
routines
[2] PetscCommDuplicate(): Using internal PETSc communicator 47674980494368
119371056
> > Since my code never finishes, I cannot get the summary files by add
> -log_summary. any other way to get summary file?
  My guess is that you are running a larger problem on the this system and
> your preallocation for the matrix is wrong. While in the small run you sent
> the preallocation is correct.
>   Usually the only thing that causes it to take forever is not the
> parallel communication but is the preallocation. After you create the
> matrix and set its preallocation call
> MatSetOption(mat, NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);  then run. It
> will stop with an error message if preallocation is wrong.
>   Barry
> > BTW, my codes are running without any problem on shared-memory desktop
> with any number of processes.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120120/72c79c52/attachment.htm>
