[petsc-users] A few questions about hdf5 viewer
Mohamad M. Nasr-Azadani mmnasr at gmail.com
Thu Jan 19 18:44:10 CST 2012
You should just create a parallel Vec to hold the 1D data. DAGetLocalInfo()
tells you all the local sizes.
Thanks Matt. But I am not sure how this would help since PETSC_COMM_WORLD
includes all the processors and in all three directions whereas the 1-D
data is only the size of Nx points.
This vector is not big at all, I could even create is on one processor. The
only concern that I have is
can I create an *.h5 file using PETSC_COMM_WORLD, dump the data, close the
file and then, re-open the file (append mode) with a different viewer
created via PETSC_COMM_SELF, and dump the coordinates vector to the end of
it? Of course, I only call PETSC_COMM_SELF on processor zero.
M
On Thu, Jan 19, 2012 at 4:33 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 19, 2012 at 6:08 PM, Mohamad M. Nasr-Azadani <mmnasr at gmail.com
> > wrote:
>> Thanks Jed.
>> My solution to that was to create a 1D vector local to for instance
>> processor zero that holds all the coordinates. Then after I dumped all the
>> parallel data to the *.h5 file, I create another viewer on processor zero
>> or PETSC_COMM_SELF and dump that new vector including tHe coordinates to
>> the end of the existing file.
>> Do you think that should be possible?
> DAGetLocalInfo() tells you all the local sizes.
>    Matt
>> Thanks,
>> Mohamad
>> On Thu, Jan 19, 2012 at 4:02 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Thu, Jan 19, 2012 at 18:00, Mohamad M. Nasr-Azadani <mmnasr at gmail.com
>>> > wrote:
>>>> What I need is just to add 3 1-D arrays of (x[Nx]+y[Ny]+z[Nz])
>>>> including the grid coordinates to the end of the *.h5 file and then later
>>>> on, I can use any visualization software to load the data using those
>>>> coordinates. I am using orthogonal grid, that's why I don't need  all the
>>>> (x,y,z) coordinates for each cell.
>>> If you want this special case, you have to manage it by hand.
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120119/d1dd7e10/attachment.htm>
