[petsc-users] A few questions about hdf5 viewer
Thu Jan 19 18:33:12 CST 2012
On Thu, Jan 19, 2012 at 6:08 PM, Mohamad M. Nasr-Azadani
<mmnasr at gmail.com>wrote:
> Thanks Jed.
> My solution to that was to create a 1D vector local to for instance
> processor zero that holds all the coordinates. Then after I dumped all the
> parallel data to the *.h5 file, I create another viewer on processor zero
> or PETSC_COMM_SELF and dump that new vector including tHe coordinates to
> the end of the existing file.
> Do you think that should be possible?
You should just create a parallel Vec to hold the 1D data. DAGetLocalInfo()
tells you all the local sizes.
   Matt
> Thanks,
> Mohamad
> On Thu, Jan 19, 2012 at 4:02 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Thu, Jan 19, 2012 at 18:00, Mohamad M. Nasr-Azadani <mmnasr at gmail.com>wrote:
>>> What I need is just to add 3 1-D arrays of (x[Nx]+y[Ny]+z[Nz]) including
>>> the grid coordinates to the end of the *.h5 file and then later on, I can
>>> use any visualization software to load the data using those coordinates. I
>>> am using orthogonal grid, that's why I don't need  all the
>>> (x,y,z) coordinates for each cell.
>> If you want this special case, you have to manage it by hand.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120119/6d5b4246/attachment.htm>
