[petsc-users] Software for load balancing to improve parallel performance to be used with PETSc
Wed Jan 4 13:43:48 CST 2012
On Wed, Jan 4, 2012 at 13:18, TAY wee-beng <zonexo at gmail.com> wrote:
> So the 1st step should be checking the load balancing. If it's more or
> less balanced, will slicing it in 3 directions further improve the speed?
You want some combination of balancing and small surface area. Slicing in 3
directions usually improves this. Depending on the anisotropy in the
physics, it could be better or worse for solver convergence rates.
> Another thing is that I hope to do some form of adaptive mesh refinement.
On a Cartesian mesh? With what sort of discretization. There are lots of
packages for this, each one targeting some class of discretizations and
problems.
> I'm a bit confused. Are partitioning software like ParMETIS, Zoltan or
> Isorropia also used for adaptive mesh refinement?
> Or which open source software can do that with PETSc and in Fortran? I
> searched and got libMesh, for use with PETSc and paramesh, which is in
> Fortran.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120104/d7636bac/attachment.htm>
