[petsc-users] Software for load balancing to improve parallel performance to be used with PETSc
TAY wee-beng zonexo at gmail.com
Tue Jan 3 16:58:10 CST 2012
I'm running a 3D Fortran CFD code. The grid used is Cartesian. The
current code is partitioned in the z direction for MPI.
For e.g. for total size z = 10, if partitioned into 5 cpus, it'll become
size z = 2 for each cpu.
Uneven grids are used to reduce the number of grids and the main bulk of
grids clusters around the center.
I read about load balancing software. I wonder if it will improve the
performance/speed of my code.
If so, what are the available choices for use with PETSc and Fortran?
Are ParMETIS, Zoltan or Isorropi recommended?
Thanks!
Yours sincerely,
TAY wee-beng
