[petsc-users] access to matnest block (0,1) ?
Sat Feb 11 14:03:48 CST 2012
On Fri, Feb 3, 2012 at 08:07, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> > I should add a MatNestGetISs() so you can get out the
> automatically-created
> > ISs. They will have the structure described below. If you want to work
> with
> > the released version, you should create the ISs yourself.
> As a user, having MatNestGetISs would be most convenient.
Pushed to petsc-dev, you have to allocate arrays to hold the returned ISs.
> > A has a contigous distribution, so the ISs must respect that. Did you try
> > creating the index sets described above? Please explain "something's
> wrong".
> Finally I understand the relation between the nesting and the
> index sets. After replacing my incorrect ISs with the correct
> ones, everything's fine (no more [0]PETSC ERROR: Arguments are
> incompatible!  [0]PETSC ERROR: Could not find index set!).
> Thanks a lot for your help, Jed, I really appreciate it.
> dr. ir. Christiaan Klaij
> CFD Researcher
> Research & Development
> E mailto:C.Klaij at marin.nl
> T +31 317 49 33 44
> MARIN
> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120211/3fbeb84f/attachment.htm>
