[petsc-users] Using superlu_dist in a direct solve
Sanjay Govindjee s_g at berkeley.edu
Wed Dec 26 19:34:56 CST 2012
For what it is worth.  I ran the problems with valgrind (before I built
the --with-shared-libraries version).
With spooles the run is essentially clean.  With superlu I see lots of
errors of the type:
==91099== Syscall param writev(vector[...]) points to uninitialised byte(s)
==91099==    at 0x1245FF2: writev (in
/usr/lib/system/libsystem_kernel.dylib)
==91099==    by 0x101209846: MPIDU_Sock_writev (in ./ex2)
==91099==    by 0x101A2BA23: ???
==91099==    by 0x1FFFFFFFB: ???
==91099==    by 0x101A2BA0F: ???
==91099==    by 0x10852053F: ???
==91099==    by 0x101A24907: ???
==91099==    by 0x7FFF5FBFE2DF: ???
==91099==    by 0x1: ???
==91099==    by 0x10120AF13: MPIDI_CH3_iSendv (in ./ex2)
==91099==  Address 0x10712d0c8 is 136 bytes inside a block of size
1,661,792 alloc'd
==91099==    at 0xC713: malloc (vg_replace_malloc.c:271)
==91099==    by 0x100D5C6DF: superlu_malloc_dist (in ./ex2)
==91099==    by 0x100D23375: doubleMalloc_dist (in ./ex2)
==91099==    by 0x100D415C1: pdgstrs (in ./ex2)
==91099==    by 0x100D3F852: pdgssvx (in ./ex2)
==91099==    by 0x1007E5D38: MatSolve_SuperLU_DIST (in ./ex2)
==91099==    by 0x1002BDA1E: MatSolve (in ./ex2)
==91099==    by 0x1009EAF55: PCApply_LU (in ./ex2)
==91099==    by 0x100AAE053: PCApply (in ./ex2)
==91099==    by 0x100B1BCEE: KSPSolve_PREONLY (in ./ex2)
==91099==    by 0x100B54F55: KSPSolve (in ./ex2)
==91099==    by 0x1000022FC: main (in ./ex2)
On 12/26/12 5:24 PM, Sanjay Govindjee wrote:
> I have re-configured/built using:
> ./configure PETSC_ARCH=gnu_shared
> -download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis}
> make  PETSC_ARCH=gnu_shared all
> make  PETSC_ARCH=gnu_shared test
> Using the same test problem (src/ksp/ksp/examples/tutorials/ex2.c), on
> the 100x100 case I get:
> sg-macbook-prolocal:tutorials sg$ make PETSC_ARCH=gnu_shared runex2spooles
> Norm of error 2.21422e-12 iterations 1
> sg-macbook-prolocal:tutorials sg$ make PETSC_ARCH=gnu_shared runex2superlu
> Norm of error 7.66145e-13 iterations 1
> One the 500x500 case I get:
> Norm of error 2.69468e-10 iterations 1
> Norm of error 419.953 iterations 1
> otool shows:
> sg-macbook-prolocal:tutorials sg$ otool -L ex2
> ex2:
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libpetsc.dylib
> (compatibility version 0.0.0, current version 0.0.0)
>     /usr/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current
> version 10.0.0)
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpichcxx.dylib
> (compatibility version 0.0.0, current version 3.0.0)
>     /usr/local/lib/libstdc++.6.dylib (compatibility version 7.0.0,
> current version 7.17.0)
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libparmetis.dylib
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmetis.dylib
> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
> (compatibility version 1.0.0, current version 1.0.0)
> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpichf90.dylib
>     /usr/local/lib/libgfortran.3.dylib (compatibility version 4.0.0,
> current version 4.0.0)
>     /usr/local/lib/libquadmath.0.dylib (compatibility version 1.0.0,
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libpmpich.dylib
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpich.dylib
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libopa.1.dylib
> (compatibility version 2.0.0, current version 2.0.0)
>     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpl.1.dylib
> (compatibility version 3.0.0, current version 3.0.0)
>     /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
> version 159.1.0)
>     /usr/local/lib/libgcc_s.1.dylib (compatibility version 1.0.0,
> On 12/26/12 3:08 PM, Matthew Knepley wrote:
>> On Wed, Dec 26, 2012 at 4:38 PM, Sanjay Govindjee <s_g at berkeley.edu
>> <mailto:s_g at berkeley.edu>> wrote:
>>     I have a macbook pro (Mac OS X 10.7.5)
>>     % uname -a
>>     Darwin sg-macbook-prolocal.local 11.4.2 Darwin Kernel Version
>>     11.4.2: Thu Aug 23 16:25:48 PDT 2012;
>>     root:xnu-1699.32.7~1/RELEASE_X86_64 x86_64
>>     I configured using:
>>     ./configure --with-cc=icc --with-fc=ifort
>>     so everything was built together.
>> Since
>>   a) you have tried other compilers
>>   b) we cannot reproduce it
>>   c) we are building the library during configure
>> I would guess that some outside library, in your default link path,
>> is contaminating
>> the executable with symbols which override some of those in SuperLU.
>> The SuperLU
>> people are not super careful about naming. Could you
>>   1) Try this same exercise using --with-shared-libraries
>>   2) Once you do that, use otool -L on the executable so we can see
>> where everything comes from
>>   Thanks,
>>       Matt
>>     On 12/26/12 1:34 PM, Hong Zhang wrote:
>>         Sanjay:
>>             hmmm....I guess that is good news -- in that superlu is
>>             not broken. However,
>>             for me
>>             not so good news since I seems that there is nasty bug
>>             lurking on my
>>             machine.
>>             Any suggestions on chasing down the error?
>>         How did you install your supelu_dist with petsc-3.3?
>>         What machine do you use?
>>         Hong
>>             On 12/26/12 1:23 PM, Hong Zhang wrote:
>>                 Sanjay:
>>                 I get
>>                 petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec -n 2
>>                 ./ex2
>>                 -ksp_monitor_short  -ksp_type preonly -pc_type lu
>>                 -pc_factor_mat_solver_package superlu_dist -m 500 -n 500
>>                 Norm of error 1.92279e-11 iterations 1
>>                 Hong
>>                     I have done some more testing of the problem,
>>                     continuing with
>>                     src/ksp/ksp/examples/tutorials/ex2.c.
>>                     The behavior I am seeing is that with smaller
>>                     problems sizes superlu_dist
>>                     is
>>                     behaving properly
>>                     but with larger problem sizes things seem to go
>>                     wrong and what goes wrong
>>                     is
>>                     apparently consistent; the error appears both
>>                     with my intel build as well
>>                     as
>>                     with my gcc build.
>>                     I have two run lines:
>>                     runex2superlu:
>>                               -@${MPIEXEC} -n 2 ./ex2
>>                     -ksp_monitor_short -m 100 -n 100
>>                     -ksp_type
>>                     preonly -pc_type lu -pc_factor_mat_solver_package
>>                     superlu_dist
>>                     runex2spooles:
>>                     -ksp_type
>>                     spooles
>>                       From my intel build, I get
>>                     sg-macbook-prolocal:tutorials sg$ make runex2superlu
>>                     sg-macbook-prolocal:tutorials sg$ make runex2spooles
>>                       From my GCC build, I get
>>                     If I change the -m 100 -n 100 to -m 500 -n 500, I
>>                     get for my intel build
>>                       From my GCC build with -m 500 -n 500, I get
>>                     Any suggestions will be greatly appreciated.
>>                     -sanjay
>>                     On 12/23/12 6:42 PM, Matthew Knepley wrote:
>>                     On Sun, Dec 23, 2012 at 9:37 PM, Sanjay Govindjee
>>                     <s_g at berkeley.edu <mailto:s_g at berkeley.edu>>
>>                     wrote:
>>                         I decided to go with
>>                         ksp/ksp/exampeles/tutorials/ex2.c; I was
>>                         unsure how
>>                         to convert the run lines for
>>                         snes/examples/ex5.c to work with a direct
>>                         solver as I am not versed in SNES options.
>>                         Notwithstanding something strange is
>>                         happening only on select examples.
>>                         With ksp/ksp/exampeles/tutorials/ex2.c and
>>                         the run line:
>>                         -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m
>>                         20 -n 20 -ksp_type preonly
>>                         superlu_dist
>>                         I get good results (of the order):
>>                         Norm of error 1.85464e-14 iterations 1
>>                         using both superlu_dist and spooles.
>>                         My BLAS/LAPACK: -llapack -lblas (so native to
>>                         my machine).
>>                         If you can guide me on a run line for the
>>                         snes ex5.c I can try that too.
>>                         I'll also try to construct a GCC build later
>>                         to see if that is an issue.
>>                     Same line on ex5, but ex2 is good enough.
>>                     However, it will not tell us
>>                     anything new. Try another build.
>>                          Matt
>>                         -sanjay
>>                         On 12/23/12 5:58 PM, Matthew Knepley wrote:
>>                         On Sun, Dec 23, 2012 at 8:08 PM, Sanjay
>>                         wrote:
>>                             Not sure what you mean by where is your
>>                             matrix?  I am simply running
>>                             ex6
>>                             in the ksp/examples/tests directory.
>>                             The reason I ran this test is because I
>>                             was seeing the same behavior
>>                             with
>>                             my finite element code (on perfectly
>>                             benign problems).
>>                             Is there a built-in test that you use to
>>                             check that superlu_dist is
>>                             working properly with petsc?
>>                             i.e. something you know that works with
>>                             with petsc 3.3-p5?
>>                         1) Run it on a SNES ex5 (or KSP ex2), which
>>                         is a nice Laplacian
>>                         2) Compare with MUMPS
>>                              Matt
>>                             -sanjay
>>                             On 12/23/12 4:56 PM, Jed Brown wrote:
>>                             Where is your matrix? It might be ending
>>                             up with a very bad pivot. If
>>                             the
>>                             problem can be reproduced, it should be
>>                             reported to the SuperLU_DIST
>>                             developers to fix. (Note that we do not
>>                             see this with other matrices.)
>>                             You
>>                             can also try MUMPS.
>>                             On Sun, Dec 23, 2012 at 6:48 PM, Sanjay
>>                             wrote:
>>                                 I wanted to use SuperLU Dist to
>>                                 perform a direct solve but seem to be
>>                                 encountering
>>                                 a problem.  I was wonder if this is a
>>                                 know issue and if there is a
>>                                 solution for it.
>>                                 The problem is easily observed using
>>                                 ex6.c in
>>                                 src/ksp/ksp/examples/tests.
>>                                 Out of the box: make runex6 produces
>>                                 a residual error of O(1e-11), all
>>                                 is well.
>>                                 I then changed the run to run on two
>>                                 processors and add the flag
>>                                 -pc_factor_mat_solver_package spooles
>>                                  this produces a residual error
>>                                 of
>>                                 O(1e-11), all is still well.
>>                                 I then switch over to
>>                                 superlu_dist and
>>                                 the
>>                                 residual error comes back as 22.6637!
>>                                  Something seems very wrong.
>>                                 My build is perfectly vanilla:
>>                                 export PETSC_DIR=/Users/sg/petsc-3.3-p5/
>>                                 export PETSC_ARCH=intel
>>                                 --with-fc=ifort  \
>>                                 make
>>                                 PETSC_ARCH=intel all
>>                                 make
>>                                 PETSC_ARCH=intel test
>>                                 -sanjay
>>                             Sanjay Govindjee, PhD, PE
>>                             Professor of Civil Engineering
>>                             Vice Chair for Academic Affairs
>>                             779 Davis Hall
>>                             Structural Engineering, Mechanics and
>>                             Materials
>>                             Department of Civil Engineering
>>                             University of California
>>                             Berkeley, CA 94720-1710
>>                             Voice: +1 510 642 6060
>>                             <tel:%2B1%20510%20642%206060>
>>                             FAX: +1 510 643 5264
>>                             <tel:%2B1%20510%20643%205264>
>>                             http://www.ce.berkeley.edu/~sanjay
>>                             <http://www.ce.berkeley.edu/%7Esanjay>
>>                             New Books:
>>                             Engineering Mechanics of Deformable
>>                             Solids: A Presentation with Exercises
>>                             http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>>                             http://ukcatalogue.oup.com/product/9780199651641.do
>>                             http://amzn.com/0199651647
>>                             Engineering Mechanics 3 (Dynamics)
>>                             http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
>>                             http://amzn.com/3642140181
>>                         What most experimenters take for granted
>>                         before they begin their
>>                         experiments is infinitely more interesting
>>                         than any results to which
>>                         their
>>                         experiments lead.
>>                         -- Norbert Wiener
>>                     What most experimenters take for granted before
>>                     they begin their
>>                     experiments
>>                     is infinitely more interesting than any results
>>                     to which their
>>                     experiments
>>                     lead.
>>                     -- Norbert Wiener
>>             779 Davis Hall
>>             Structural Engineering, Mechanics and Materials
>>             Voice: +1 510 642 6060 <tel:%2B1%20510%20642%206060>
>>             FAX: +1 510 643 5264 <tel:%2B1%20510%20643%205264>
>>             New Books:
>>     779 Davis Hall
>>     New Books:
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
> 779 Davis Hall
> s_g at berkeley.edu
> New Books:
779 Davis Hall
s_g at berkeley.edu
New Books:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121226/a661225c/attachment-0001.html>
