[petsc-users] Using superlu_dist in a direct solve
Sanjay Govindjee s_g at berkeley.edu
Wed Dec 26 19:24:25 CST 2012
I have re-configured/built using:
./configure PETSC_ARCH=gnu_shared
-download-{spooles,parmetis,superlu_dist,prometheus,mpich,ml,hypre,metis} --with-shared-libraries
make  PETSC_ARCH=gnu_shared all
make  PETSC_ARCH=gnu_shared test
Using the same test problem (src/ksp/ksp/examples/tutorials/ex2.c), on
the 100x100 case I get:
sg-macbook-prolocal:tutorials sg$ make PETSC_ARCH=gnu_shared runex2spooles
Norm of error 2.21422e-12 iterations 1
sg-macbook-prolocal:tutorials sg$ make PETSC_ARCH=gnu_shared runex2superlu
Norm of error 7.66145e-13 iterations 1
One the 500x500 case I get:
Norm of error 2.69468e-10 iterations 1
Norm of error 419.953 iterations 1
otool shows:
sg-macbook-prolocal:tutorials sg$ otool -L ex2
ex2:
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libpetsc.dylib (compatibility
version 0.0.0, current version 0.0.0)
     /usr/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current
version 10.0.0)
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpichcxx.dylib
(compatibility version 0.0.0, current version 3.0.0)
     /usr/local/lib/libstdc++.6.dylib (compatibility version 7.0.0,
current version 7.17.0)
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libparmetis.dylib
(compatibility version 0.0.0, current version 0.0.0)
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmetis.dylib (compatibility
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
(compatibility version 1.0.0, current version 1.0.0)
/System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpichf90.dylib
     /usr/local/lib/libgfortran.3.dylib (compatibility version 4.0.0,
current version 4.0.0)
     /usr/local/lib/libquadmath.0.dylib (compatibility version 1.0.0,
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libpmpich.dylib
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpich.dylib (compatibility
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libopa.1.dylib (compatibility
version 2.0.0, current version 2.0.0)
     /Users/sg/petsc-3.3-p5/gnu_shared/lib/libmpl.1.dylib (compatibility
version 3.0.0, current version 3.0.0)
     /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
version 159.1.0)
     /usr/local/lib/libgcc_s.1.dylib (compatibility version 1.0.0,
On 12/26/12 3:08 PM, Matthew Knepley wrote:
> On Wed, Dec 26, 2012 at 4:38 PM, Sanjay Govindjee <s_g at berkeley.edu
> <mailto:s_g at berkeley.edu>> wrote:
>     I have a macbook pro (Mac OS X 10.7.5)
>     % uname -a
>     Darwin sg-macbook-prolocal.local 11.4.2 Darwin Kernel Version
>     11.4.2: Thu Aug 23 16:25:48 PDT 2012;
>     root:xnu-1699.32.7~1/RELEASE_X86_64 x86_64
>     I configured using:
>     ./configure --with-cc=icc --with-fc=ifort
>     so everything was built together.
> Since
>   a) you have tried other compilers
>   b) we cannot reproduce it
>   c) we are building the library during configure
> I would guess that some outside library, in your default link path, is
> contaminating
> the executable with symbols which override some of those in SuperLU.
> The SuperLU
> people are not super careful about naming. Could you
>   1) Try this same exercise using --with-shared-libraries
>   2) Once you do that, use otool -L on the executable so we can see
> where everything comes from
>   Thanks,
>       Matt
>     On 12/26/12 1:34 PM, Hong Zhang wrote:
>         Sanjay:
>             hmmm....I guess that is good news -- in that superlu is
>             not broken. However,
>             for me
>             not so good news since I seems that there is nasty bug
>             lurking on my
>             machine.
>             Any suggestions on chasing down the error?
>         How did you install your supelu_dist with petsc-3.3?
>         What machine do you use?
>         Hong
>             On 12/26/12 1:23 PM, Hong Zhang wrote:
>                 Sanjay:
>                 I get
>                 petsc-3.3/src/ksp/ksp/examples/tutorials>mpiexec -n 2
>                 ./ex2
>                 -ksp_monitor_short  -ksp_type preonly -pc_type lu
>                 -pc_factor_mat_solver_package superlu_dist -m 500 -n 500
>                 Norm of error 1.92279e-11 iterations 1
>                 Hong
>                     I have done some more testing of the problem,
>                     continuing with
>                     src/ksp/ksp/examples/tutorials/ex2.c.
>                     The behavior I am seeing is that with smaller
>                     problems sizes superlu_dist
>                     is
>                     behaving properly
>                     but with larger problem sizes things seem to go
>                     wrong and what goes wrong
>                     is
>                     apparently consistent; the error appears both with
>                     my intel build as well
>                     as
>                     with my gcc build.
>                     I have two run lines:
>                     runex2superlu:
>                               -@${MPIEXEC} -n 2 ./ex2
>                     -ksp_monitor_short -m 100 -n 100
>                     -ksp_type
>                     preonly -pc_type lu -pc_factor_mat_solver_package
>                     superlu_dist
>                     runex2spooles:
>                     -ksp_type
>                     spooles
>                       From my intel build, I get
>                     sg-macbook-prolocal:tutorials sg$ make runex2superlu
>                     sg-macbook-prolocal:tutorials sg$ make runex2spooles
>                       From my GCC build, I get
>                     If I change the -m 100 -n 100 to -m 500 -n 500, I
>                     get for my intel build
>                       From my GCC build with -m 500 -n 500, I get
>                     Any suggestions will be greatly appreciated.
>                     -sanjay
>                     On 12/23/12 6:42 PM, Matthew Knepley wrote:
>                     On Sun, Dec 23, 2012 at 9:37 PM, Sanjay Govindjee
>                     <s_g at berkeley.edu <mailto:s_g at berkeley.edu>>
>                     wrote:
>                         I decided to go with
>                         ksp/ksp/exampeles/tutorials/ex2.c; I was
>                         unsure how
>                         to convert the run lines for
>                         snes/examples/ex5.c to work with a direct
>                         solver as I am not versed in SNES options.
>                         Notwithstanding something strange is happening
>                         only on select examples.
>                         With ksp/ksp/exampeles/tutorials/ex2.c and the
>                         run line:
>                         -@${MPIEXEC} -n 2 ./ex2 -ksp_monitor_short -m
>                         20 -n 20 -ksp_type preonly
>                         superlu_dist
>                         I get good results (of the order):
>                         Norm of error 1.85464e-14 iterations 1
>                         using both superlu_dist and spooles.
>                         My BLAS/LAPACK: -llapack -lblas (so native to
>                         my machine).
>                         If you can guide me on a run line for the snes
>                         ex5.c I can try that too.
>                         I'll also try to construct a GCC build later
>                         to see if that is an issue.
>                     Same line on ex5, but ex2 is good enough. However,
>                     it will not tell us
>                     anything new. Try another build.
>                          Matt
>                         -sanjay
>                         On 12/23/12 5:58 PM, Matthew Knepley wrote:
>                         On Sun, Dec 23, 2012 at 8:08 PM, Sanjay
>                         wrote:
>                             Not sure what you mean by where is your
>                             matrix?  I am simply running
>                             ex6
>                             in the ksp/examples/tests directory.
>                             The reason I ran this test is because I
>                             was seeing the same behavior
>                             with
>                             my finite element code (on perfectly
>                             benign problems).
>                             Is there a built-in test that you use to
>                             check that superlu_dist is
>                             working properly with petsc?
>                             i.e. something you know that works with
>                             with petsc 3.3-p5?
>                         1) Run it on a SNES ex5 (or KSP ex2), which is
>                         a nice Laplacian
>                         2) Compare with MUMPS
>                              Matt
>                             -sanjay
>                             On 12/23/12 4:56 PM, Jed Brown wrote:
>                             Where is your matrix? It might be ending
>                             up with a very bad pivot. If
>                             the
>                             problem can be reproduced, it should be
>                             reported to the SuperLU_DIST
>                             developers to fix. (Note that we do not
>                             see this with other matrices.)
>                             You
>                             can also try MUMPS.
>                             On Sun, Dec 23, 2012 at 6:48 PM, Sanjay
>                             wrote:
>                                 I wanted to use SuperLU Dist to
>                                 perform a direct solve but seem to be
>                                 encountering
>                                 a problem.  I was wonder if this is a
>                                 know issue and if there is a
>                                 solution for it.
>                                 The problem is easily observed using
>                                 ex6.c in
>                                 src/ksp/ksp/examples/tests.
>                                 Out of the box: make runex6 produces a
>                                 residual error of O(1e-11), all
>                                 is well.
>                                 I then changed the run to run on two
>                                 processors and add the flag
>                                 -pc_factor_mat_solver_package spooles
>                                  this produces a residual error
>                                 of
>                                 O(1e-11), all is still well.
>                                 I then switch over to
>                                 superlu_dist and
>                                 the
>                                 residual error comes back as 22.6637!
>                                  Something seems very wrong.
>                                 My build is perfectly vanilla:
>                                 export PETSC_DIR=/Users/sg/petsc-3.3-p5/
>                                 export PETSC_ARCH=intel
>                                 --with-fc=ifort  \
>                                 make PETSC_DIR=/Users/sg/petsc-3.3-p5/
>                                 PETSC_ARCH=intel all
>                                 PETSC_ARCH=intel test
>                                 -sanjay
>                             Sanjay Govindjee, PhD, PE
>                             Professor of Civil Engineering
>                             Vice Chair for Academic Affairs
>                             779 Davis Hall
>                             Structural Engineering, Mechanics and
>                             Materials
>                             Department of Civil Engineering
>                             University of California
>                             Berkeley, CA 94720-1710
>                             Voice: +1 510 642 6060
>                             <tel:%2B1%20510%20642%206060>
>                             FAX: +1 510 643 5264
>                             <tel:%2B1%20510%20643%205264>
>                             http://www.ce.berkeley.edu/~sanjay
>                             <http://www.ce.berkeley.edu/%7Esanjay>
>                             New Books:
>                             Engineering Mechanics of Deformable
>                             Solids: A Presentation with Exercises
>                             http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>                             http://ukcatalogue.oup.com/product/9780199651641.do
>                             http://amzn.com/0199651647
>                             Engineering Mechanics 3 (Dynamics)
>                             http://www.springer.com/materials/mechanics/book/978-3-642-14018-1
>                             http://amzn.com/3642140181
>                         What most experimenters take for granted
>                         before they begin their
>                         experiments is infinitely more interesting
>                         than any results to which
>                         their
>                         experiments lead.
>                         -- Norbert Wiener
>                     What most experimenters take for granted before
>                     they begin their
>                     experiments
>                     is infinitely more interesting than any results to
>                     which their
>                     experiments
>                     lead.
>                     -- Norbert Wiener
>             779 Davis Hall
>             Structural Engineering, Mechanics and Materials
>             Voice: +1 510 642 6060 <tel:%2B1%20510%20642%206060>
>             FAX: +1 510 643 5264 <tel:%2B1%20510%20643%205264>
>             New Books:
>     779 Davis Hall
>     New Books:
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
779 Davis Hall
s_g at berkeley.edu
New Books:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121226/c35dc93b/attachment-0001.html>
