[petsc-users] VecSetBlockSize with release 3.3
Aldo Bonfiglioli aldo.bonfiglioli at unibas.it
Fri Dec 21 06:04:31 CST 2012
Dear all,
I am in the process of upgrading from 3.2  to 3.3.
I am a little bit puzzled by the following change:
> VecSetBlockSize() cannot be called after VecCreateSeq() or
> VecCreateMPI() and must be called before VecSetUp() or
> VecSetFromOptions() or before either VecSetType() or VecSetSizes()
With the earlier release I used to do the following:
         CALL VecCreateSeq(PETSC_COMM_SELF,NPOIN*NOFVAR,DT,IFAIL)
C
C
          IF(NOFVAR.GT.1) CALL VecSetBlockSize(DT,NOFVAR,IFAIL)
with 3.3 it looks like the following is required :
          CALL VecCreate(PETSC_COMM_SELF,DT,IFAIL)
          CALL VecSetType(DT,VECSEQ,IFAIL)
          CALL VecSetSizes(DT,NPOIN*NOFVAR,PETSC_DECIDE,IFAIL)
Is there a simpler (i.e. less library calls) way to achieve the same result?
Aldo
Dr. Aldo Bonfiglioli
Associate professor of Fluid Flow Machinery
Scuola di Ingegneria
Universita' della Basilicata
V.le dell'Ateneo lucano, 10 85100 Potenza ITALY
tel:+39.0971.205203 fax:+39.0971.205215
Publications list <http://publicationslist.org/aldo.bonfiglioli>
