[petsc-users] valgrind complains about string functions
Alexander Grayver agrayver at gfz-potsdam.de
Tue Dec 4 05:07:33 CST 2012
Jed, Satish,
suppression file is a nice option, thanks.
On 03.12.2012 17:53, Satish Balay wrote:
> On Mon, 3 Dec 2012, Alexander Grayver wrote:
>> Hello,
>> I'm using PETSc-3.3-p4 compiled with ICC 12.0 + IntelMPI 4.0.3 and getting a
>> bunch of the errors related to the string functions:
>> ==22020== Conditional jump or move depends on uninitialised value(s)
>> ==22020==    at 0x4D3109: __intel_sse2_strcpy (in /home/main)
>> ==22020==    by 0xE87D51D: PetscStrcpy (in
>> /home/lib/petsc-3.3-p4/intelmpi-intel12-double-release-c-shared/lib/libpetsc.so)
>> ==22020==    by 0xE87B6A4: PetscStrallocpy (in
>> ==22020==    by 0xE796769: PetscFListGetPathAndFunction (in
>> ==22020==    by 0xE79652A: PetscFListAdd (in
>> ==22020==    by 0xE64ACB8: MatMFFDRegister (in
>> ==22020==    by 0xE64FA7D: MatMFFDRegisterAll (in
>> ==22020==    by 0xE64F65B: MatMFFDInitializePackage (in
>> ==22020==    by 0xE48D8C2: MatInitializePackage (in
>> ==22020==    by 0xE5157DB: MatCreate (in
>> ==22020==    by 0xE29A74C: MatCreateSeqAIJ (in
>> Same thing for PetscStrncat etc.
>> There was similar question two years ago in this mailing list and advice was
>> to use a different compiler. It is not an option for me.
> You can always use a separate build of PETSc with gcc,--download-mpich
> to get a valgrind clean build [for debugging purposes]
>> Thus, my question is can those errors potentially cause any serious troubles?
> Generally we can ignore issues valgrind finds in system/compiler
> libraries. [Jed has a valid explanation for this one].
> And generally valgrind provides 'default suppression files' for known
> glibc versions. But for such issues as with ifc, you can ask valgrind
> to create a supression file - and then rerun valgrind with this custom
> supression file - to get more readable output.
> Satish
>> I came across with time trying to debug a weird segmentation fault.
>> Thanks.
Alexander
