[petsc-users] Strange error(?) message
Mohammad Mirzadeh mirzadeh at gmail.com
Tue Apr 10 02:08:12 CDT 2012
Just built petsc-dev and it did not help. I'm going to look into the code
to see if my graph is "ill-formed" in some sense. Just hope the problem is
from my side not a real bug in ParMetis!
On Mon, Apr 9, 2012 at 8:46 PM, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
> ok. Thanks Jed. I'll try petsc-dev to see if it fixes the problem.
> Thanks everyone.
> On Mon, Apr 9, 2012 at 8:42 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Mon, Apr 9, 2012 at 22:37, Mohammad Mirzadeh <mirzadeh at gmail.com>wrote:
>>> Thanks Sean. I'm using Petsc 3.2-p6 along with ParMetis 4.0.2. Since
>>> this was not supported with 3.2-p6, and previous versions had bugs, I built
>>> parmetis myself and used --with-parmetis-include and --with-parmetis-lib
>>> flags to build petsc.
>>> Should I switch to petsc-dev?
>> Yes, and use --download-metis --download-parmetis because the version
>> upstream has some bugs for which the patches have not been applied.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120410/99e9ebfd/attachment.htm>
