[petsc-users] Strange error(?) message
Mon Apr 9 22:25:17 CDT 2012
  This is part of the excellent error handing in ParMetis (sarcasm intended), you would have found it rather quickly in the debugger. (ParMetis code follows)
idx_t BSearch(idx_t n, idx_t *array, idx_t key)
  idx_t a=0, b=n, c;
  while (b-a > 8) {
    c = (a+b)>>1;
    if (array[c] > key)
      b = c;
    else
      a = c;
  for (c=a; c<b; c++) {
    if (array[c] == key)
      return c;
  errexit("Key %"PRIDX" not found!\n", key);
  return 0;
  So either it is a bug in ParMetis or ParMetis is being passed a "ill-formed" graph and not detecting the "ill-formed" graph cleanly.
   What to do? Well we can't spend out lives debugging other peoples libraries so ..... I am not sure what to do next? Validate that Parmetis is getting reasonable input?
   Barry
On Apr 9, 2012, at 10:19 PM, Mohammad Mirzadeh wrote:
> -on_error_attach_debugger does not start the debugger. I traced it upto the following call:  MatPartitioningApply(). It runs fine up until that function call and then gives the error.
> Also, to make things even look more weird, I got the following once I was running it:
> Key 10176 not found!
> INTERNAL ERROR: Invalid error class (66) encountered while returning from
> PMPI_Waitall.  Please file a bug report.
> Do you happen to know what that could mean? The funny thing is, it only happened once!
> On Mon, Apr 9, 2012 at 7:57 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Apr 9, 2012 at 21:56, Mohammad Mirzadeh <mirzadeh at gmail.com> wrote:
> :( that's all I see. Do you mean running with -on_error_attach_debugger?
> Sure, or directly in a debugger. Does execution make it to main? Something is either not catching errors or is improperly calling exit() or similar.
