[petsc-users] ex52_integrateElement.cu
David Fuentes fuentesdt at gmail.com
Tue Apr 3 12:36:02 CDT 2012
thank you Matt,
David
On Mon, Apr 2, 2012 at 9:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Mar 28, 2012 at 6:42 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Mar 28, 2012 at 6:25 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>> Yes. This would work.
>>> I had trouble compiling in single precision using the some of the
>>> external package options I was using for double.
>> Okay,  getting on it now.
> Okay, I have tested using PetscReal=double with floats on the GPU. If you
> want doubles on the GPU, you can
> currently change PETSc/FEM.py:434. I am deciding what the best way to
> specify this type is.
>   Thanks,
>      Matt
>>    Matt
>>> On Wed, Mar 28, 2012 at 4:57 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Wed, Mar 28, 2012 at 4:12 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>> works!
>>>> Excellent. Now, my thinking was that GPUs are most useful doing single
>>>> work, but
>>>> I can see the utility of double accuracy for a residual.
>>>> My inclination is to define another type, say GPUReal, and use it for
>>>> all kernels.
>>>> Would that do what you want?
>>>>    Matt
>>>>> SCRGP2$ make ex52
>>>>> /usr/bin/mpicxx -o ex52.o -c -O0 -g -fPIC
>>>>> -I/opt/apps/PETSC/petsc-dev/include
>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/include
>>>>> -I/opt/apps/cuda/4.0/cuda/include -I/usr/include -I/usr/include/mpich2
>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>>>> nvcc -G -O0 -g -arch=sm_10  -c --compiler-options="-O0 -g   -fPIC
>>>>>  -D__INSDIR__=src/snes/examples/tutorials/"  ex52_integrateElement.cu
>>>>>  ex52_gpu_inline.h(7): warning: variable "points_0" was declared but
>>>>> never referenced
>>>>> ex52_gpu_inline.h(21): warning: variable "Basis_0" was declared but
>>>>> never referenced
>>>>> never referenced
>>>>> ex52_gpu_inline.h(13): warning: variable "weights_0" was declared but
>>>>> never referenced
>>>>> never referenced
>>>>> ex52_gpu_inline.h(28): warning: variable "BasisDerivatives_0" was
>>>>> declared but never referenced
>>>>> never referenced
>>>>> never referenced
>>>>> never referenced
>>>>> never referenced
>>>>> never referenced
>>>>> /usr/bin/mpicxx -O0 -g   -o ex52 ex52.o ex52_integrateElement.o
>>>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>>>>  -lpetsc
>>>>> -ltriangle -lX11 -lpthread -lmetis -Wl,-rpath,/opt/apps/cuda/4.0/cuda/lib64
>>>>> -L/opt/apps/cuda/4.0/cuda/lib64 -lcufft -lcublas -lcudart -lcusparse
>>>>> -Wl,-rpath,/opt/epd-7.1-2-rh5-x86_64/lib -L/opt/epd-7.1-2-rh5-x86_64/lib
>>>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5
>>>>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>>>> -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -ldl -lmpich -lopa -lpthread -lrt
>>>>> -lgcc_s -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx
>>>>> -lstdc++ -ldl -lmpich -lopa -lpthread -lrt -lgcc_s -ldl
>>>>> SCRGP2$ ./ex52 -dim 2 -compute_function -show_residual -batch -gpu
>>>>> GPU layout grid(1,2,1) block(3,1,1) with 1 batches
>>>>>  N_t: 3, N_cb: 1
>>>>> Residual:
>>>>> Vector Object: 1 MPI processes
>>>>>   type: seq
>>>>> -0.25
>>>>> -0.5
>>>>> 0.25
>>>>> -0.5
>>>>> -1
>>>>> 0.5
>>>>> 0.25
>>>>> 0.5
>>>>> 0.75
>>>>> Residual:
>>>>>   type: seq
>>>>> -0.25
>>>>> -0.5
>>>>> 0.25
>>>>> -0.5
>>>>> -1
>>>>> 0.5
>>>>> 0.25
>>>>> 0.5
>>>>> 0.75
>>>>> On Wed, Mar 28, 2012 at 1:37 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>>> sure. will do.
>>>>>> On Wed, Mar 28, 2012 at 1:23 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Wed, Mar 28, 2012 at 1:14 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>>>>> thanks! its running, but I seem to be getting different answer for
>>>>>>>> cpu/gpu ?
>>>>>>>> i had some floating point problems on this Tesla M2070 gpu before,
>>>>>>>> but adding the '-arch=sm_20' option seemed to fix it last time.
>>>>>>>> is the assembly in single precision ? my 'const PetscReal
>>>>>>>> jacobianInverse' being passed in are doubles
>>>>>>> Yep, that is the problem. I have not tested anything in double. I
>>>>>>> have not decided exactly how to handle it. Can you
>>>>>>> make another ARCH --with-precision=single and make sure it works,
>>>>>>> and then we can fix the double issue?
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>>  N_t: 3, N_cb: 1
>>>>>>>> Residual:
>>>>>>>>   type: seq
>>>>>>>> 0
>>>>>>>> 755712
>>>>>>>> 0
>>>>>>>> -58720
>>>>>>>> -2953.13
>>>>>>>> 0.375
>>>>>>>> 1.50323e+07
>>>>>>>> 0.875
>>>>>>>> 0
>>>>>>>> SCRGP2$
>>>>>>>> Residual:
>>>>>>>>   type: seq
>>>>>>>> -0.25
>>>>>>>> -0.5
>>>>>>>> 0.25
>>>>>>>> -0.5
>>>>>>>> -1
>>>>>>>> 0.5
>>>>>>>> 0.25
>>>>>>>> 0.5
>>>>>>>> 0.75
>>>>>>>> On Wed, Mar 28, 2012 at 11:55 AM, Matthew Knepley <
>>>>>>>>> On Wed, Mar 28, 2012 at 11:45 AM, David Fuentes <
>>>>>>>>> fuentesdt at gmail.com> wrote:
>>>>>>>>>> The example seems to be running on cpu with '-batch' but
>>>>>>>>>> i'm getting errors in line 323 with the '-gpu' option
>>>>>>>>>> [0]PETSC ERROR: IntegrateElementBatchGPU() line 323 in
>>>>>>>>>> src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>>>> should this possibly be PetscScalar ?
>>>>>>>>> No.
>>>>>>>>>> -  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>>>> sizeof(float));CHKERRQ(ierr);
>>>>>>>>>> +  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>>>> sizeof(PetscScalar));CHKERRQ(ierr);
>>>>>>>>>> SCRGP2$ python
>>>>>>>>>> $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py 2 1 1 1
>>>>>>>>>> laplacian ex52.h
>>>>>>>>>> ['/opt/apps/PETSC/petsc-dev/bin/pythonscripts/PetscGenerateFEMQuadrature.py',
>>>>>>>>>> '2', '1', '1', '1', 'laplacian', 'ex52.h']
>>>>>>>>>> 2 1 1 1 laplacian
>>>>>>>>>> [{(-1.0, -1.0): [(1.0, ())]}, {(1.0, -1.0): [(1.0, ())]}, {(-1.0,
>>>>>>>>>> 1.0): [(1.0, ())]}]
>>>>>>>>>> {0: {0: [0], 1: [1], 2: [2]}, 1: {0: [], 1: [], 2: []}, 2: {0:
>>>>>>>>>> Perm: [0, 1, 2]
>>>>>>>>>> Creating /home/fuentes/snestutorial/ex52.h
>>>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu.h
>>>>>>>>>> 1.0): [(1.0, ())]}]
>>>>>>>>>> Perm: [0, 1, 2]
>>>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu_inline.h
>>>>>>>>>> SCRGP2$ make ex52
>>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/include
>>>>>>>>>> -I/opt/apps/cuda/4.1/cuda/include -I/opt/apps/PETSC/petsc-dev/include/sieve
>>>>>>>>>> -I/opt/MATLAB/R2011a/extern/include -I/usr/include
>>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/cbind/include
>>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/forbind/include
>>>>>>>>>> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>>>>>>>>> nvcc -O0 -g -arch=sm_20  -c --compiler-options="-O0 -g   -fPIC
>>>>>>>>>> -I/usr/include/mpich2    -D__INSDIR__=src/snes/examples/tutorials/"
>>>>>>>>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
>>>>>>>>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib  -lpetsc
>>>>>>>>>> -ltriangle -lX11 -lpthread -lsuperlu_dist_3.0 -lcmumps -ldmumps -lsmumps
>>>>>>>>>> -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lscalapack -lblacs
>>>>>>>>>> -Wl,-rpath,/opt/apps/cuda/4.1/cuda/lib64 -L/opt/apps/cuda/4.1/cuda/lib64
>>>>>>>>>> -Wl,-rpath,/opt/MATLAB/R2011a/sys/os/glnxa64:/opt/MATLAB/R2011a/bin/glnxa64:/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>>>> -L/opt/MATLAB/R2011a/bin/glnxa64 -L/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>>>>>>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5 -lexoIIv2for -lexodus
>>>>>>>>>> -lnetcdf_c++ -lnetcdf -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>>>>>>>>> /bin/rm -f ex52.o ex52_integrateElement.o
>>>>>>>>>> Residual:
>>>>>>>>>>   type: seq
>>>>>>>>>> -0.25
>>>>>>>>>> -0.5
>>>>>>>>>> 0.25
>>>>>>>>>> -0.5
>>>>>>>>>> -1
>>>>>>>>>> 0.5
>>>>>>>>>> 0.25
>>>>>>>>>> 0.5
>>>>>>>>>> 0.75
>>>>>>>>>> [0]PETSC ERROR: FormFunctionLocalBatch() line 679 in
>>>>>>>>>> src/snes/examples/tutorials/ex52.c
>>>>>>>>>> [0]PETSC ERROR: SNESDMComplexComputeFunction() line 431 in
>>>>>>>>>> src/snes/utils/damgsnes.c
>>>>>>>>>> [0]PETSC ERROR: main() line 1021 in
>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 35) - process 0
>>>>>>>>> This is failing on cudaMalloc(), which means your card is not
>>>>>>>>> available for running. Are you trying to run on your laptop?
>>>>>>>>> If so, applications like Preview can lock up the GPU. I know of no
>>>>>>>>> way to test this in CUDA while running. I just close
>>>>>>>>> apps until it runs.
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> On Tue, Mar 27, 2012 at 8:37 PM, Matthew Knepley <
>>>>>>>>>>> On Tue, Mar 27, 2012 at 2:10 PM, Blaise Bourdin <bourdin at lsu.edu
>>>>>>>>>>> > wrote:
>>>>>>>>>>>> On Mar 27, 2012, at 1:23 PM, Matthew Knepley wrote:
>>>>>>>>>>>> On Tue, Mar 27, 2012 at 12:58 PM, David Fuentes <
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> I had a question about the status of example 52.
>>>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52.c
>>>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>>>>>>> Can this example be used with a DM object created from an
>>>>>>>>>>>>> unstructured exodusII mesh, DMMeshCreateExodus, And the FEM assembly done
>>>>>>>>>>>>> on GPU ?
>>>>>>>>>>>> 1) I have pushed many more tests for it now. They can be run
>>>>>>>>>>>> using the Python build system
>>>>>>>>>>>>   ./config/builder2.py check src/snes/examples/tutorials/ex52.c
>>>>>>>>>>>>   in fact, you can build any set of files this way.
>>>>>>>>>>>> 2) The Exodus creation has to be converted to DMComplex from
>>>>>>>>>>>> DMMesh. That should not take me very long. Blaise maintains that
>>>>>>>>>>>>      so maybe there will be help :) You will just replace
>>>>>>>>>>>> DMComplexCreateBoxMesh() with DMComplexCreateExodus(). If you request
>>>>>>>>>>>>      it, I will bump it up the list.
>>>>>>>>>>>> DMMeshCreateExodusNG is much more flexible
>>>>>>>>>>>> than DMMeshCreateExodus in that it can read meshes with multiple element
>>>>>>>>>>>> types and should have a much lower memory footprint. The code should be
>>>>>>>>>>>> fairly easy to read. you can email me directly if you have specific
>>>>>>>>>>>> questions. I had looked at creating a DMComplex and it did not look too
>>>>>>>>>>>> difficult, as long as interpolation is not needed. I have plans to
>>>>>>>>>>>> write DMComplexCreateExodus, but haven't had time too so far. Updating the
>>>>>>>>>>>> Vec viewers and readers may be a bit more involved. In perfect world, one
>>>>>>>>>>>> would write an EXODUS viewer following the lines of the VTK and HDF5 ones.
>>>>>>>>>>> David and Blaise,  I have converted this function, now
>>>>>>>>>>> DMComplexCreateExodus(). Its not tested, but I think
>>>>>>>>>>> Blaise has some stuff we can use to test it.
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> Blaise
>>>>>>>>>>>> Let me know if you can run the tests.
>>>>>>>>>>>>   Thanks
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> David
>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> Department of Mathematics and Center for Computation &
>>>>>>>>>>>> Technology
>>>>>>>>>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>>>>>>>>>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
>>>>>>>>>>>> http://www.math.lsu.edu/~bourdin
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120403/e6f99f00/attachment-0001.htm>
