[petsc-users] ex52_integrateElement.cu
Mon Apr 2 21:37:46 CDT 2012
On Wed, Mar 28, 2012 at 6:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Mar 28, 2012 at 6:25 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>> Yes. This would work.
>> I had trouble compiling in single precision using the some of the
>> external package options I was using for double.
> Okay,  getting on it now.
Okay, I have tested using PetscReal=double with floats on the GPU. If you
want doubles on the GPU, you can
currently change PETSc/FEM.py:434. I am deciding what the best way to
specify this type is.
     Matt
>    Matt
>> On Wed, Mar 28, 2012 at 4:57 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Wed, Mar 28, 2012 at 4:12 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>> works!
>>> Excellent. Now, my thinking was that GPUs are most useful doing single
>>> work, but
>>> I can see the utility of double accuracy for a residual.
>>> My inclination is to define another type, say GPUReal, and use it for
>>> all kernels.
>>> Would that do what you want?
>>>    Matt
>>>> SCRGP2$ make ex52
>>>> /usr/bin/mpicxx -o ex52.o -c -O0 -g -fPIC
>>>> -I/opt/apps/PETSC/petsc-dev/include
>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/include
>>>> -I/opt/apps/cuda/4.0/cuda/include -I/usr/include -I/usr/include/mpich2
>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>>> nvcc -G -O0 -g -arch=sm_10  -c --compiler-options="-O0 -g   -fPIC
>>>>  -D__INSDIR__=src/snes/examples/tutorials/"  ex52_integrateElement.cu
>>>>  ex52_gpu_inline.h(7): warning: variable "points_0" was declared but
>>>> never referenced
>>>> ex52_gpu_inline.h(21): warning: variable "Basis_0" was declared but
>>>> never referenced
>>>> never referenced
>>>> ex52_gpu_inline.h(13): warning: variable "weights_0" was declared but
>>>> never referenced
>>>> never referenced
>>>> ex52_gpu_inline.h(28): warning: variable "BasisDerivatives_0" was
>>>> declared but never referenced
>>>> never referenced
>>>> never referenced
>>>> never referenced
>>>> never referenced
>>>> never referenced
>>>> /usr/bin/mpicxx -O0 -g   -o ex52 ex52.o ex52_integrateElement.o
>>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-single-dbg/lib
>>>>  -lpetsc
>>>> -ltriangle -lX11 -lpthread -lmetis -Wl,-rpath,/opt/apps/cuda/4.0/cuda/lib64
>>>> -L/opt/apps/cuda/4.0/cuda/lib64 -lcufft -lcublas -lcudart -lcusparse
>>>> -Wl,-rpath,/opt/epd-7.1-2-rh5-x86_64/lib -L/opt/epd-7.1-2-rh5-x86_64/lib
>>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5
>>>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>>> -L/usr/lib/gcc/x86_64-linux-gnu/4.4.3 -ldl -lmpich -lopa -lpthread -lrt
>>>> -lgcc_s -lmpichf90 -lgfortran -lm -lm -lmpichcxx -lstdc++ -lmpichcxx
>>>> -lstdc++ -ldl -lmpich -lopa -lpthread -lrt -lgcc_s -ldl
>>>> SCRGP2$ ./ex52 -dim 2 -compute_function -show_residual -batch -gpu
>>>> GPU layout grid(1,2,1) block(3,1,1) with 1 batches
>>>>  N_t: 3, N_cb: 1
>>>> Residual:
>>>> Vector Object: 1 MPI processes
>>>>   type: seq
>>>> -0.25
>>>> -0.5
>>>> 0.25
>>>> -0.5
>>>> -1
>>>> 0.5
>>>> 0.25
>>>> 0.5
>>>> 0.75
>>>> Residual:
>>>>   type: seq
>>>> -0.25
>>>> -0.5
>>>> 0.25
>>>> -0.5
>>>> -1
>>>> 0.5
>>>> 0.25
>>>> 0.5
>>>> 0.75
>>>> On Wed, Mar 28, 2012 at 1:37 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>> sure. will do.
>>>>> On Wed, Mar 28, 2012 at 1:23 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Wed, Mar 28, 2012 at 1:14 PM, David Fuentes <fuentesdt at gmail.com>wrote:
>>>>>>> thanks! its running, but I seem to be getting different answer for
>>>>>>> cpu/gpu ?
>>>>>>> i had some floating point problems on this Tesla M2070 gpu before,
>>>>>>> but adding the '-arch=sm_20' option seemed to fix it last time.
>>>>>>> is the assembly in single precision ? my 'const PetscReal
>>>>>>> jacobianInverse' being passed in are doubles
>>>>>> Yep, that is the problem. I have not tested anything in double. I
>>>>>> have not decided exactly how to handle it. Can you
>>>>>> make another ARCH --with-precision=single and make sure it works, and
>>>>>> then we can fix the double issue?
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>>  N_t: 3, N_cb: 1
>>>>>>> Residual:
>>>>>>>   type: seq
>>>>>>> 0
>>>>>>> 755712
>>>>>>> 0
>>>>>>> -58720
>>>>>>> -2953.13
>>>>>>> 0.375
>>>>>>> 1.50323e+07
>>>>>>> 0.875
>>>>>>> 0
>>>>>>> SCRGP2$
>>>>>>> Residual:
>>>>>>>   type: seq
>>>>>>> -0.25
>>>>>>> -0.5
>>>>>>> 0.25
>>>>>>> -0.5
>>>>>>> -1
>>>>>>> 0.5
>>>>>>> 0.25
>>>>>>> 0.5
>>>>>>> 0.75
>>>>>>> On Wed, Mar 28, 2012 at 11:55 AM, Matthew Knepley <knepley at gmail.com
>>>>>>> > wrote:
>>>>>>>> On Wed, Mar 28, 2012 at 11:45 AM, David Fuentes <
>>>>>>>> fuentesdt at gmail.com> wrote:
>>>>>>>>> The example seems to be running on cpu with '-batch' but
>>>>>>>>> i'm getting errors in line 323 with the '-gpu' option
>>>>>>>>> [0]PETSC ERROR: IntegrateElementBatchGPU() line 323 in
>>>>>>>>> src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>>> should this possibly be PetscScalar ?
>>>>>>>> No.
>>>>>>>>> -  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>>> sizeof(float));CHKERRQ(ierr);
>>>>>>>>> +  ierr = cudaMalloc((void**) &d_coefficients,         Ne*N_bt *
>>>>>>>>> sizeof(PetscScalar));CHKERRQ(ierr);
>>>>>>>>> SCRGP2$ python
>>>>>>>>> $PETSC_DIR/bin/pythonscripts/PetscGenerateFEMQuadrature.py 2 1 1 1
>>>>>>>>> laplacian ex52.h
>>>>>>>>> ['/opt/apps/PETSC/petsc-dev/bin/pythonscripts/PetscGenerateFEMQuadrature.py',
>>>>>>>>> '2', '1', '1', '1', 'laplacian', 'ex52.h']
>>>>>>>>> 2 1 1 1 laplacian
>>>>>>>>> [{(-1.0, -1.0): [(1.0, ())]}, {(1.0, -1.0): [(1.0, ())]}, {(-1.0,
>>>>>>>>> 1.0): [(1.0, ())]}]
>>>>>>>>> {0: {0: [0], 1: [1], 2: [2]}, 1: {0: [], 1: [], 2: []}, 2: {0: []}}
>>>>>>>>> Perm: [0, 1, 2]
>>>>>>>>> Creating /home/fuentes/snestutorial/ex52.h
>>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu.h
>>>>>>>>> 1.0): [(1.0, ())]}]
>>>>>>>>> Perm: [0, 1, 2]
>>>>>>>>> Creating /home/fuentes/snestutorial/ex52_gpu_inline.h
>>>>>>>>> SCRGP2$ make ex52
>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/include
>>>>>>>>> -I/opt/apps/cuda/4.1/cuda/include -I/opt/apps/PETSC/petsc-dev/include/sieve
>>>>>>>>> -I/opt/MATLAB/R2011a/extern/include -I/usr/include
>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/cbind/include
>>>>>>>>> -I/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/forbind/include
>>>>>>>>> -I/usr/include/mpich2 -D__INSDIR__=src/snes/examples/tutorials/ ex52.c
>>>>>>>>> nvcc -O0 -g -arch=sm_20  -c --compiler-options="-O0 -g   -fPIC
>>>>>>>>> -I/usr/include/mpich2    -D__INSDIR__=src/snes/examples/tutorials/"
>>>>>>>>>  -Wl,-rpath,/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib
>>>>>>>>> -L/opt/apps/PETSC/petsc-dev/gcc-4.4.3-mpich2-1.2-epd-sm_20-dbg/lib  -lpetsc
>>>>>>>>> -ltriangle -lX11 -lpthread -lsuperlu_dist_3.0 -lcmumps -ldmumps -lsmumps
>>>>>>>>> -lzmumps -lmumps_common -lpord -lparmetis -lmetis -lscalapack -lblacs
>>>>>>>>> -Wl,-rpath,/opt/apps/cuda/4.1/cuda/lib64 -L/opt/apps/cuda/4.1/cuda/lib64
>>>>>>>>> -Wl,-rpath,/opt/MATLAB/R2011a/sys/os/glnxa64:/opt/MATLAB/R2011a/bin/glnxa64:/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>>> -L/opt/MATLAB/R2011a/bin/glnxa64 -L/opt/MATLAB/R2011a/extern/lib/glnxa64
>>>>>>>>> -leng -lmex -lmx -lmat -lut -licudata -licui18n -licuuc
>>>>>>>>> -lmkl_rt -lmkl_intel_thread -lmkl_core -liomp5 -lexoIIv2for -lexodus
>>>>>>>>> -lnetcdf_c++ -lnetcdf -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.4.3
>>>>>>>>> /bin/rm -f ex52.o ex52_integrateElement.o
>>>>>>>>> Residual:
>>>>>>>>>   type: seq
>>>>>>>>> -0.25
>>>>>>>>> -0.5
>>>>>>>>> 0.25
>>>>>>>>> -0.5
>>>>>>>>> -1
>>>>>>>>> 0.5
>>>>>>>>> 0.25
>>>>>>>>> 0.5
>>>>>>>>> 0.75
>>>>>>>>> [0]PETSC ERROR: FormFunctionLocalBatch() line 679 in
>>>>>>>>> src/snes/examples/tutorials/ex52.c
>>>>>>>>> [0]PETSC ERROR: SNESDMComplexComputeFunction() line 431 in
>>>>>>>>> src/snes/utils/damgsnes.c
>>>>>>>>> [0]PETSC ERROR: main() line 1021 in
>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 35) - process 0
>>>>>>>> This is failing on cudaMalloc(), which means your card is not
>>>>>>>> available for running. Are you trying to run on your laptop?
>>>>>>>> If so, applications like Preview can lock up the GPU. I know of no
>>>>>>>> way to test this in CUDA while running. I just close
>>>>>>>> apps until it runs.
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> On Tue, Mar 27, 2012 at 8:37 PM, Matthew Knepley <
>>>>>>>>>> On Tue, Mar 27, 2012 at 2:10 PM, Blaise Bourdin <bourdin at lsu.edu>wrote:
>>>>>>>>>>> On Mar 27, 2012, at 1:23 PM, Matthew Knepley wrote:
>>>>>>>>>>> On Tue, Mar 27, 2012 at 12:58 PM, David Fuentes <
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> I had a question about the status of example 52.
>>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52.c
>>>>>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/file/a8e2f2c19319/src/snes/examples/tutorials/ex52_integrateElement.cu
>>>>>>>>>>>> Can this example be used with a DM object created from an
>>>>>>>>>>>> unstructured exodusII mesh, DMMeshCreateExodus, And the FEM assembly done
>>>>>>>>>>>> on GPU ?
>>>>>>>>>>> 1) I have pushed many more tests for it now. They can be run
>>>>>>>>>>> using the Python build system
>>>>>>>>>>>   ./config/builder2.py check src/snes/examples/tutorials/ex52.c
>>>>>>>>>>>   in fact, you can build any set of files this way.
>>>>>>>>>>> 2) The Exodus creation has to be converted to DMComplex from
>>>>>>>>>>> DMMesh. That should not take me very long. Blaise maintains that
>>>>>>>>>>>      so maybe there will be help :) You will just replace
>>>>>>>>>>> DMComplexCreateBoxMesh() with DMComplexCreateExodus(). If you request
>>>>>>>>>>>      it, I will bump it up the list.
>>>>>>>>>>> DMMeshCreateExodusNG is much more flexible
>>>>>>>>>>> than DMMeshCreateExodus in that it can read meshes with multiple element
>>>>>>>>>>> types and should have a much lower memory footprint. The code should be
>>>>>>>>>>> fairly easy to read. you can email me directly if you have specific
>>>>>>>>>>> questions. I had looked at creating a DMComplex and it did not look too
>>>>>>>>>>> difficult, as long as interpolation is not needed. I have plans to
>>>>>>>>>>> write DMComplexCreateExodus, but haven't had time too so far. Updating the
>>>>>>>>>>> Vec viewers and readers may be a bit more involved. In perfect world, one
>>>>>>>>>>> would write an EXODUS viewer following the lines of the VTK and HDF5 ones.
>>>>>>>>>> David and Blaise,  I have converted this function, now
>>>>>>>>>> DMComplexCreateExodus(). Its not tested, but I think
>>>>>>>>>> Blaise has some stuff we can use to test it.
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> Blaise
>>>>>>>>>>> Let me know if you can run the tests.
>>>>>>>>>>>   Thanks
>>>>>>>>>>>      Matt
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> David
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> Department of Mathematics and Center for Computation & Technology
>>>>>>>>>>> Louisiana State University, Baton Rouge, LA 70803, USA
>>>>>>>>>>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
>>>>>>>>>>> http://www.math.lsu.edu/~bourdin
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120402/bfdfce0e/attachment-0001.htm>
