[petsc-users] code hangs inside SUPERLU DIST
Sun Apr 1 15:01:34 CDT 2012
On Sun, Apr 1, 2012 at 2:18 PM, Wen Jiang <jiangwen84 at gmail.com> wrote:
> Sorry for the last incomplete email. Please forget about it. Let me finish
> it up here.
> Hello Everyone,
> I am using KSPPRECONLY type ksp with SUPERLU DIST. However, I found my
> code hangs inside superlu_dist solver and never finishes.
> The problem I am solving is a time-dependent nonlinear pde and I use fully
> Newton-Raphson for each time step. So my code will look like,
> For Time STEP = From start to end
>     For Newton-Raphson Iterations = From 1 to max iterations
>         Calculate Matrix A; (A is different for each Newton-Raphson
> iteration)
>         Create KSP
>         KSPSetOperator(A,A,same_nonzero_pattern)
>         KSPSolve;
>        KSPDestroy;
>     END Newton-Raphson Iterations
> End Time STEP
> Could you give me any hints what the problem might be? I am using Petsc
> 3.1 p8 and superlu dist v2.4. And my code works fine with KSP iterative
> solver like GMRES.
There are a list of things I would try:
1) Upgrading to the latest release
2) Trying MUMPS instead of SuperLU_dist
3) Get a stack trace from gdb to determine where it is hanging.
I would do whichever one is easiest.
    Matt
> Regards,
> Wen
> On Sun, Apr 1, 2012 at 3:12 PM, Wen Jiang <jiangwen84 at gmail.com> wrote:
>> Hello Everyone,
>> fully Newton-Raphson for each time step. So my code will look like,
>> For Time STEP = start to end
>>     For Newton-Raphson Iterations = 1 to max iterations
>>         Calculate Matrix A;
>> End Time STEP
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120401/a1e5611e/attachment.htm>
