[petsc-users] code hangs inside SUPERLU DIST
Wen Jiang jiangwen84 at gmail.com
Sun Apr 1 14:18:32 CDT 2012
Sorry for the last incomplete email. Please forget about it. Let me finish
it up here.
Hello Everyone,
I am using KSPPRECONLY type ksp with SUPERLU DIST. However, I found my code
hangs inside superlu_dist solver and never finishes.
The problem I am solving is a time-dependent nonlinear pde and I use fully
Newton-Raphson for each time step. So my code will look like,
For Time STEP = From start to end
    For Newton-Raphson Iterations = From 1 to max iterations
        Calculate Matrix A; (A is different for each Newton-Raphson
iteration)
        Create KSP
        KSPSetOperator(A,A,same_nonzero_pattern)
        KSPSolve;
       KSPDestroy;
    END Newton-Raphson Iterations
End Time STEP
Could you give me any hints what the problem might be? I am using Petsc 3.1
p8 and superlu dist v2.4. And my code works fine with KSP iterative solver
like GMRES.
Wen
On Sun, Apr 1, 2012 at 3:12 PM, Wen Jiang <jiangwen84 at gmail.com> wrote:
> Hello Everyone,
> code hangs inside superlu_dist solver and never finishes.
> For Time STEP = start to end
>     For Newton-Raphson Iterations = 1 to max iterations
>         Calculate Matrix A;
> End Time STEP
> 3.1 p8 and superlu dist v2.4.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120401/27e715d2/attachment.htm>
