[petsc-users] configure mpirun problem
charles reid charlesreid1 at gmail.com
Mon May 23 15:53:38 CDT 2011
Hi -
Thanks for the responses.  Setting LD_LIBRARY_PATH has no effect on the
process, since the problem isn't with LD_LIBRARY_PATH or the compilation
process, its with how the executable is being run.
I also tried Petsc 3.1 but got the same problem (with and without
LD-LIBRARY-PATH set).
The --with-batch flag ended up being the solution that worked, once
configure stopped I was able to run conftest through mpirun and then run
reconfigure.py, and everything worked as expected.
Thanks again for the help!
Charles
On Mon, May 23, 2011 at 13:23, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 23 May 2011, Matthew Knepley wrote:
> > On Mon, May 23, 2011 at 2:16 PM, charles reid <charlesreid1 at gmail.com
> >wrote:
> > > Hi -
> > > I'm trying to install Petsc and linking to OpenMPI, but running into a
> > > conflict with the compiler test.  If I specify my MPI installation
> directory
> > > and my mpiexec command, like so:
> > > ./configure \
> > >  --prefix=/uufs/
> > > chpc.utah.edu/common/home/u0552682/pkg/petsc/3.0.0_incendio \
> > >  --with-x=false \
> > >  --with-matlab=false \
> > >  --download-f-blas-lapack=ifneeded \
> > >  --with-mpi-dir=/uufs/
> chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3\<http://chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3%5C>
> > >  --with-mpiexec=/uufs/
> > > chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpirun \
> > >  --with-blas-lapack-dir=/usr/lib \Checking for program /uufs/
> > > chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc...found
> > >           Defined make macro "CC" to "/uufs/
> > > chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc"
> > >           Pushing language C
> > > sh: /uufs/
> chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc-c -o
> conftest.o   conftest.c
> > > Executing: /uufs/
> > > chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc -c -o
> > > sh:
> > > sh: /uufs/
> > > Executing: /uufs/
> > > sh:
> > >                                           Pushing language C
> > >                                           Popping language C
> > >                                           Pushing language Cxx
> > >                                           Popping language Cxx
> > >                                           Pushing language FC
> > >                                           Popping language FC
> > >                   Pushing language C                  Popping language
> C
> > > sh: /uufs/
> > > -o conftest     conftest.o
> > > Executing: /uufs/
> > > chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc  -o
> > > conftest     conftest.o
> > > sh:
> > > sh: /uufs/
> > > Executing: /uufs/
> > > sh:                      Pushing language C
> > >                       Popping language C
> > > sh: /uufs/
> > > Executing: /uufs/
> > > conftest     conftest.o
> > > sh:Executing: ./conftest
> > > sh: ./conftest
> > > Executing: ./conftestsh:
> > > ERROR while running executable: Could not execute
> './conftest':./conftest:
> > > error while loading shared libraries: libmpi.so.0: cannot open shared
> object
> > > file: No such file or directory
> > >  --with-shared=0 \
> > > The underlying problem can be demonstrated with a simple C hello world
> > > program:
> > > $ cat test.c
> > > #include <stdio.h>
> > > main()
> > >   printf ("Hello World!\n");
> > > $ /uufs/chpc.utah.edu/common/home/u0552682/pkg/openmpi/1.4.3/bin/mpicc -o
> > > test.o test.c
> > > $ ./test.o
> > > ./test.o: error while loading shared libraries: libmpi.so.0: cannot
> open
> > > shared object file: No such file or directory
> > > Running the executable with mpirun alone shows the same error (similar
> to
> > > this thread at OpenMPI list:
> > > http://www.open-mpi.org/community/lists/users/2006/07/1691.php)
> > > $ mpirun -np 1 ./test.o
> open
> > > and ultimately the resolution is to specify the full path of mpirun
> when
> > > running the executable (as per the response to the above thread,
> > > http://www.open-mpi.org/community/lists/users/2006/07/1692.php):
> > > $ `which mpirun` -np 1 ./test.o
> > > Hello World!
> > > So my question is, why does Petsc's compiler test insist on running the
> > > mpicc-built test executable in an incorrect way (i.e. ./conftestsh
> instead
> > > of /path/to/mpiexec ./conftest)?  And how can I compile with OpenMPI
> > > support?  I'm unable to bypass this by specifying CC and CXX, as I just
> run
> > > into problems later on with mpi_init not being found.
> > There are many, many ways to run an executable. We count on 'sh
> > <executable>' as a default, and if that does not work
> >  then you can run configure using --with-batch.
> With openMPI - the primary issue is:
> They [openmpi folks] expect openmpi users to set LD_LIBRARY_PATH
> before using their compilers. So you should set that before running
> PETSc configure.
> Also - you are using older 3.0.0 version. 3.1 might have some
> workarrounds for openmpi [for sure petsc-dev does..]
> Satish
> >     Matt
> > > Charles
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110523/981be8e2/attachment-0001.htm>
