[petsc-users] Direct solver for 3D-FEM
Fri May 20 09:14:26 CDT 2011
On May 20, 2011, at 7:55 AM, Thomas Witkowski wrote:
> Could one of you explain me why direct solvers (I make use of UMFPACK) seems to work quite bad for 3D-FEM? For a small test case, I take a unite square/box and refine it globally (bisectioning of triangle/tetrahedrons). I solve a six order PDE  (that leads to symmetric but indefinite matrices) on it. In 2D the resulting system has 49.923 rows with 808.199 non zeros, UMFPACK solves the system within 2.8 seconds. For 3D I've refine the box such that the resulting matrix has more or less the same number of non zeros, in this case 898.807 on 27.027 rows. UMFPACK needs 32 seconds to solve it, so more than 10 time as for the 2D case. Even if I make use of fourth order Lagrange functions for the 2D case, which leads to much denser matrices (49.923 rows and 2.705.927 non zeros), UMFPACK solves it within 3.2 seconds. Is there any good reason for it?
> Thomas
   Thomas,
     This difference was originally explained by Alan George in seminal work on sparse direct solvers in the late 60s and early 70s. He has several publications that explain the reason for the difference and a book (which just happens to be online at http://www.cse.illinois.edu/courses/cs598mh/george_liu.pdf). This difference between 2 and 3 d direct solvers is just a fact of life.
    Barry
