[petsc-users] Direct solver for 3D-FEM
Thomas Witkowski thomas.witkowski at tu-dresden.de
Fri May 20 08:59:55 CDT 2011
Jed Brown wrote:
> On Fri, May 20, 2011 at 15:16, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
>     Thanks for the information. One related question: The system that
>     is solved here is a 3x3 block matrix: Two of these blocks are
>     empty, two are the discretized (FEM) identity, three are the
>     discretized Laplace operator
> What equation? Have you assumed special boundary conditions? Problems
> like elasticity and Stokes normally need a symmetric stress tensor.
> Only for constant coefficients and certain boundary conditions, is it
> okay to use the "block Laplacian" form.
It is the so called phase field crystal equation (PFC, a 6th-order
nonlinear parabolic PDE). The block structure results because my code
can solve only system of 2nd-order PDEs. Because there is a Laplace^3 in
the original equation I get all the Laplacian due to operator spliting.
The whole block looks as follows: [-L, 0, I;  I, -L, 0; C, I, -L], where
I is the identity operator, L the Laplace operator and C = 2 L - eps I +
v I, with eps a number and v the solution of the old timestep). There
are many different ways to write the system. This here is not symmetric,
but is more diagonal dominant. Boundary conditions are zero-flux on all
boundaries.
>     and one block is the discretization of a complex sum of operators.
>     At all, there are only three different blocks. Can I make somehow
>     advantages of this structure? I could create the three inverses of
>     the three different blocks, but exists than a cheap/simple way to
>     produce the action of the inverse of the whole 3x3 block matrix?
> For the special case of a Kronecker product, you can solve using
> solves with the blocks, but not in the general case. Consider the
> structured grid 2D Laplacian [A, -I; -I, A] where A is the tridiagonal
> problem for a 1D Laplacian plus 2*I on the diagonal. If you could
> build a direct solver for the 2D using direct solvers for the 1D
> problem, then you would have an O(n) algorithm for a direct solve of a
> 2D Laplacian.
> You can, however, build an iterative method from the blocks. If each
> block is built separately, you can (with petsc-dev) put them into
> MatNest and use PCFieldSplit with direct solves in splits.
I will check this.
> An alternative is to interlace the degrees of freedom and use the
> (S)BAIJ matrix format. This will reduce the amount of memory needed
> for your matrix (by using a more efficient storage format) and will
> improve the memory performance. Unfortunately, there are no
> third-party direct solvers for BAIJ. Note that your assembly code can
> always call MatSetValuesBlocked() (or ..BlockedLocal()) regardless of
> the matrix format, so you can switch between AIJ and BAIJ at run-time.
> Why bother with a direct solver if your problem has constant
> coefficients?
