[petsc-users] -log_summary output
Fri May 13 10:27:54 CDT 2011
On May 13, 2011, at 8:56 AM, ilyas ilyas wrote:
> Hello,
> Would you please help me to understand two attached -log_summary outputs. Both are from same cfd-petsc code, taken at different times at the end of first time-step.
> Domain : 256^3, periodic (defined in DA's)
> Ncores : 256
> After a couple of hundered iterations, one or more cores killed/dumped and my code exits.This is not an issue with a coarse resolution (say 32^3,64^3) May this be related to my code?
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
--- Event Stage 0: Main Stage
   Distributed array     1              0            0     0
                 Vec   597            579    340156096     0
         Vec Scatter     3              1          868     0
           Index Set     9              9      1700440     0
I'm thinking there may be a memory leak with the vectors. During the run you sent us it is creating 597 vectors but only destroying 579. If each time-step you are leaking vectors it will eventually run out of memory and stop.  Check that all your Vec creations have a matching destroy. Also make sure that is true for matrices. You can run with the options -malloc -malloc_debug -malloc_dump as a test and it will print out all the memory that PETSc used that was not freed. Ideally this will always report nothing after a run. BTW: Don't use these options when running for performance, just use them to test for memory leaks.
> (Assuming enough memory available in the system). What is wrong with MatXXX ?
   Not sure what you mean here? There is no MatXXX in the output you sent us. It is true that since the matrices take up a lot of memory when memory is leaked often it crashes when trying to allocate a matrix.
   Barry
> Thanks a lot,
> Ilyas.
> Energy Inst.
> ITU
> <185432.out><185433.out>
