[petsc-users] -log_summary output
ilyas ilyas ilyascfd at gmail.com
Fri May 13 08:56:03 CDT 2011
Hello,
Would you please help me to understand two attached -log_summary outputs.
Both are from same cfd-petsc code, taken at different times at the end of
first time-step.
Domain : 256^3, periodic (defined in DA's)
Ncores : 256
After a couple of hundered iterations, one or more cores killed/dumped and
my code exits.This is not an issue with a coarse resolution (say 32^3,64^3)
May this be related to my code? (Assuming enough memory available in the
system). What is wrong with MatXXX ?
Thanks a lot,
Ilyas.
Energy Inst.
ITU
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110513/b8add6ad/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110513/b8add6ad/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110513/b8add6ad/attachment-0003.obj>
