[petsc-users] A beginner question about a PETSc example
Nan.Jia at Dartmouth.edu Nan.Jia at Dartmouth.edu
Tue May 10 14:11:14 CDT 2011
Hello all the PETSc users and developers,
I just started learning and exploring PETSc recently. I have a problem
for the example: .../src/ksp/ksp/examples/ex2f.f
I run several times with different numbers of processors. Here are the
results.
nan_jia at mir:/thayerfs/research/anatoly/NAN/Petsc/petsc-3.1-p8/src/ksp/ksp/examples/tutorials$ mpiexec -np 1 ./ex2f -m 100 -n
100
Norm of error 0.8936E-02 iterations    65
nan_jia at mir:/thayerfs/research/anatoly/NAN/Petsc/petsc-3.1-p8/src/ksp/ksp/examples/tutorials$ mpiexec -np 2 ./ex2f -m 100 -n
100
Norm of error 0.3148E-01 iterations    89
nan_jia at mir:/thayerfs/research/anatoly/NAN/Petsc/petsc-3.1-p8/src/ksp/ksp/examples/tutorials$ mpiexec -np 3 ./ex2f -m 100 -n
100
Norm of error 0.3193E-01 iterations    92
What is weird to me is that with more processors, the norm does not
decrease but increases, do does the number of iterations.
I also try to compare .../src/ksp/ksp/examples/ex2f.f with
.../src/ksp/ksp/examples/ex1f.f  to see the difference between the
sequential and parallel code in order to understand how PETSc
parallelizes the code.
This is my first use the PETSc mailing list. Thanks everyone.
Best,
Nan
