[petsc-users] SPAI preconditioner in PETSc
Jed Brown jed at 59A2.org
Tue May 10 06:58:01 CDT 2011
On Tue, May 10, 2011 at 13:44, Danesh Daroui <danesh.daroui at ltu.se> wrote:
> I also checked the SPAI web page and they have also mentioned that there
> is an interface for PETSc but nothing more.
Configure with --download-spai. You might also try parasails from Hypre
(another SPAI implementation), configure with --download-hypre, then run
with -pc_type hypre -pc_hypre_type parasails.
> I have also another questions. In my code, even when the solution is
> converged withing few iterations, the result is far different from
> correct solution that I have. I am suspecting that there something wrong
> with matrix filling in my code. Is there anyway to use direct solver in
> PETSc so I will verify that my matrices are correct before trying
> iterative solvers?
-pc_type lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110510/adea9d15/attachment.htm>
