[petsc-users] ML Statistics like BoomerAMG Print Statistics
Travis Austin austin at txcorp.com
Mon May 2 11:03:49 CDT 2011
I'm looking for an option to ML that gives information about the hierarchy of matrices constructed by ML
like that which is available with BoomerAMG using the -pc_hypre_print_boomeramg_statistics.
In HYPRE one can use this to get operator complexity etc that tells you the cost of the AMG algorithm.
It seems that there are far fewer options with ML (probably because it has not been a part of PETSc for
as long) and I have not yet found an option like -pc_ml_print_statistics.  Does anyone know of such an
option?
Travis
Travis Austin, Ph.D.
Tech-X Corporation
5621 Arapahoe Ave, Suite A
Boulder, CO 80303
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110502/c89c8eb9/attachment.htm>
